Bmw 16V K1100 1380 Engine
847 replies to this topic
#106 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 June 2016 - 07:16 PM
Today I took out the old SPi fuel pump and fitted the new after market MPI pump for minispares, which seems like it has come via a supplier Glencoe (they seem decent)
https://www.minispar...|Back to search
No fitting instructons included
I searched a bit on here and over at the 16v forum and i found bits and pieces of info but nothing comprehensive. So I thought I would document my process, with the hope it might help others. Though, this is not a definite guide, just how I did it. Any input appreciated.
So here is the old (larger) pump out if the tank and the new Mpi pump layed beside.
D83156C7-9F24-466C-9D63-072E8F58B33F_zps
Old pump removed, I wanted to use the base support the old pump rested on, but that meant the pipe that connects to the pump was too long.
1B190246-E2DE-4546-83C2-172619AA0A14_zps
I cut about 25mm of the pipe and deburred and filed the end round.
B91DDFD2-A250-4DC1-9BB2-E45164EBFFEC_zps
New pump installed, I have seen others cable tie the pump on to support it better. I felt this pulled the pump too much. I had some thicker fuel hose so I added that to the return pipe and then cable tied it all together.
Then the wiring: Large speed connector to Live and the smaller to Ground. CAN SOMEONE CONFIRM THIS: I found conflicting info on here, but another member had posted that minispares had told him large - live and small -ground.
71C6E5C6-294E-4F72-A746-D7151D81B4FF_zps
#107 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 June 2016 - 07:18 PM
Seems the water pump pulley will rub on the oil hose (which runs from the block to the head), Is there smaller diameter pulley in the market?
http://www.theminifo...r-pump-pulleys/
4.2" here
4.75" here
3.875" here
3 7/8" (3.875) seems to be the smallest but given what was said in the link above it seems the largest pulley that will fit is best as the water pump can go too fast especially at higher revs.
Many thanks!
Although I understand the pump will spin quicker but I really need a smaller pulley for clearance. I am gonna measure up and see which i need. hopefully not too small.
#108 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 June 2016 - 07:19 PM
I actually fitted a larger diameter pulley for the reason above (pump was knackered after 1,200 miles). You may also find you need a spacer so the fan misses pipes, but yours look differently routed than mine.
 I actually had a spacer on the pump. it made the clearance a bit better. but it would still rub.
#109 Streetscreamer
Streetscreamer
  • 16 posts
  • Local Club: Mini Seven Club Netherlands
Posted 19 June 2016 - 08:49 AM
.... as I am preparing a same kind of block, I studied your photos well.
Nice build, nice parts.
However one doubt: I see the pistons installed with the large valve pockets at the exhaust side, the small valve pockets to the intake side.
As the intake valves are bigger than the exhaust valves, shouldn't it be installed in the oposite way....?
Sorry I hope I am not right, as your engine is already build up quite far now....
regards, Bart
#110 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 19 June 2016 - 03:45 PM
Good spot, think you have saved minisilverbullet a potential expensive rebuild further down the line!
#111 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 19 June 2016 - 04:13 PM
+1 on the spot!
Ps I've got a small water pump pulley if you need it
#112 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 19 June 2016 - 04:53 PM
It is the right way round.  The big pocket is on the back side of the engine.  The head is offset towards the back of the block, hence the valves being closer to the cylinder.
Edited by AndyR, 19 June 2016 - 04:57 PM.
#113 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 June 2016 - 06:42 PM
I would hope they are the right way around it was Specialist components who built the short block.
Though better safe than sorry, so i had a look at their build guide and yip it is correct:
81ED0BBA-7624-4F36-B187-2A8614AA98FC_zps
F90C422D-74DA-450F-8C2A-A87C9453AE1E_zps
Though many thanks for being observant! One reason I have this thread is to catch any mistakes i might be making.
#114 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 June 2016 - 06:43 PM
+1 on the spot!
is it the 4.2" version? or the smallest 3.85"
#115 59 Speed
59 Speed
  • 674 posts
Posted 19 June 2016 - 07:26 PM
+1 on the spot!
It's the 3.875" diameter one.
I searched high and low for a medium or 4.2" pulley as my  4.75" was very close to the head (especially with the wrong belt, fits fine now though  :shy:)
#116 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 June 2016 - 08:07 PM
yeah the only 4.2 inch one i can find is the 50 quid MED one.
#117 Streetscreamer
Streetscreamer
  • 16 posts
Posted 19 June 2016 - 08:59 PM
Happy that I was not right.
I will keep a sharp eye on this matter when building my block.
Many other builds show the oposite.
I think the pockets are not that thight around the valves, however you prefer a certain shroud around the valve.
When drybuilding my block I will check with some Playdoh of my daughter what is the clearance between the valves and the pockets
#118 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 20 June 2016 - 06:53 PM
I feel I am getting close to lift the engine into the car.
Some questions:
What are these three holes at the rear of the crankcase?
E2F19E2D-ECBC-44DF-B488-D97DC8D42651_zps
Where should I fit the fuel pressure regulator, beside the tank or in the engine bay?
#119 nicklouse
  • 18,562 posts
Posted 20 June 2016 - 07:02 PM
Non Mini engine mounts. Regulator tends to be fitted close to the carbs or injectors.
#120 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 20 June 2016 - 07:07 PM
Cheers Nick!
