The Swedish postman arrived today lets call him Postman Patrik:
Lots of silly parts you don't really budget for in a build (gaskets, fasteners, clips etc)
To clear the cam belt you need to take of the some of the web of the water pump, the SC guide also states to shave the some material of the top of the water pump to clear the head, I trial fitted my pump and it fitted fine, so no need.
Pump fitted! feels like things are coming together.
Next up was fitting the radiator sensor to the "chinese" alloy rad, I did have fears that it wouldn't fit, since the communication with the seller was a little unclear. but it fitted perfectly.
When I ordered the Kit from SC i ordered their hose kit. I am not sure how the pipe from water pump to bottom radiator fit, but I guess it will become more apparent when i have the rad fitted. Basically the pipes must intertwine but I am not sure which way. Also there might be clearance issues so i fuss i need to trim the pipes a little.
