Bmw 16V K1100 1380 Engine
847 replies to this topic
#76 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 08 June 2016 - 08:18 PM
Yes it would, the 2 front (closest to the block) connect to the drains in the head and the 3rd would then be a breather.
Edited by AndyR, 08 June 2016 - 08:18 PM.
#77 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 08 June 2016 - 08:50 PM
I would connect the breather on the drain on the back of the block into a T piece then one side going to that breather on the front plate and the other connection left to a catch tank. I found the two smaller drains almost useless compared to the one on end plate. I ran it up with clear hoses and almost nothing came through the back hoses, but if you have provisions to fit them then it can't hurt to plumb them up.
A breather on the cam cover is a worth while mod too.
#78 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 June 2016 - 12:12 PM
Just received a mail from SC regarding the engine breathers.
They suggest that all engine breathers are brought together to a catch tank located under the inner wing and filter it there (keep fumes out the cabin).
There is also a breather pipe on the throttle bodies which i overlooked, this should be blocked.
#79 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 June 2016 - 12:28 PM
What capacity catch tank should I look at?
#80 nicklouse
  • 18,562 posts
Posted 09 June 2016 - 01:34 PM
Ok for Motor sport use we are told a Minimum of 1 Liter should be available  I ran two 1/2 washer bottles.
you can buy many different types some even have sight tubes so you can see if there is any oil in there.
you should not really catch much or any so I would not be too concerned. just have a look at what you can find.
#81 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 June 2016 - 02:13 PM
Found this one seems quite slim enough to mount in the inner wing ( it is 1 litre)
Size: 180mm x 105mm x 65mm
Screen%20Shot%202016-06-09%20at%2016.10.
#82 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 09 June 2016 - 02:58 PM
Swiftune do a nice under wing catch tank!
#83 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 June 2016 - 03:24 PM
I saw that unfortunately it has 1" outlets.
#84 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 09 June 2016 - 04:39 PM
You might be able to find a reducer pipe.  As suggested it might be wise to plumb the two breathers together - you would then want a bigger collector pipe to the catch tank.  You dont want to strangulate the breathing system.
#85 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 June 2016 - 05:31 PM
I think I will have a filter breather on the normal crankcase canister typo breather. Then run the oil drain box breather and the cam plate breather to the catch tank, each on their own line. The catch tank posted above has two inlets. I can then add a flyer breather onto the catch tank and mount it under the wing.
That should be alright?
I just mocked up a box to the dimensions of the can above and it seems nice a neat.
#86 matty...
matty...
  • 605 posts
Posted 09 June 2016 - 05:45 PM
If you need a custom tank making up, I can make anything you need.
#87 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 June 2016 - 05:36 PM
Always nice with a parts delivery...
MED crank pulley and filter housing!
Quality is excellent! And just slightly more expensive than standard parts.
64B0B078-070A-4AF6-8C8D-DC2748420C14_zps
49EF3306-A78A-4547-BF86-FB2769298CAE_zps
CFCF2575-7324-41A7-BCF3-9BADA4DE5CDA_zps
#88 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 June 2016 - 08:53 PM
Looks great fitted!
17DBD7AB-F701-4B6B-9DC2-3143E972A384_zps
Shame it is never going to work. the MED Damper must be both thicker and larger in diameter than the standard item, despite i being sold as an "s" damper.
the picture below shows the situation with the SC trigger wheel fitted. I would need to space out the sensor bracket about 1cm and shave 4mm off the sensor itself for it too work. Open to suggestion though…...
89FEF0A8-6BA6-41B1-94F3-A8DD5E98DC18_zps
Generally a frustrating night in the garage I offered uo the oil filter housing, It is supplied with socket head bolts, but the clearance with the housing itself makes it impossible to get any sort of tool to tighten up the bolts.
36A62B25-4EB0-49D7-B8D3-A641509AB08E_zps
oh and then there is the washers suppled… they foul the side of the hosing so can't be used (not a big deal, but why even send them).
60A24761-A7A5-4E87-97FA-AE2EC55A9D3F_zps
On the positive side, the new wiring loom from SC arrived. Plugs straight into the relay packs, so looks easy to use. But there are a couple of ring and spade connectors, which i need some explaining on where they connect. No instructions provided. I assume they are for the starter X3, oil pressure and for the alternator X3.
Oh then there is this on the loom. This is for the air temp sensor but surely it shouldn't look like this?
DE161C8F-5664-4A42-9268-68503D836622_zps
Time for a beer!
#89 nicklouse
  • 18,562 posts
Posted 10 June 2016 - 09:15 PM
The S damper is a different size and shape to a 1275/1300 damper. Less on the diameter but thicker.
#90 Domneon
Domneon
  • 720 posts
Posted 10 June 2016 - 09:32 PM
There should be some terminals crimping on the ends and then pushed into the plug
http://www.vehicle-w...roof-connectors
^^ That sort of thing
