Bmw 16V K1100 1380 Engine
847 replies to this topic
#841 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 21 November 2019 - 06:58 AM
Im seriously tempted by a K1100... seriously! Love your build!
Do it Sam.....
#842 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 27 July 2020 - 08:43 PM
Hi Craig, just a quick question. Did you keep the breather line from the fuel tank to the carbon bottle under the passenger front wing?
Cheers Paul.
#843 Chris1992
Chris1992
  • 2,022 posts
Posted 27 November 2020 - 07:01 PM
If its any help mine (SC 7 port)start in the same place but run clockwise. Its the same ecu and mapping.
You mean like this:
950354B3-3901-400F-BC97-3DE24F188FC2_zps
As you say I guess they are the same!
Hey man, sorry if you answered this later on in the thread, but did this turn out to be the correct firing order?
I've just fitted a brand new k1200 1380 into my car that's been built completely built for me by Specialist Components, but I'm having trouble getting a spark. The plug leads are currently fitted to the coil with plugs 2 and 4 swapped around (this is how they were when the engine was delivered), so I'm thinking that may be wrong for starters. I'm also only getting spark from ignition outputs 1 and 2. Nothing from 3 or 4. Would you say this has to be either a faulty coil or plug leads? Any advice would be much appreciated! grin.gif
Edited by Chris1992, 27 November 2020 - 07:03 PM.
#844 sonscar
sonscar
  • 3,249 posts
Posted 28 November 2020 - 09:56 AM
IT could be the coil,Depending on how far you would like to proceed I would remove the plugs and change over the 12 and 34 driver wires at the coil to see if the fault stayed on the same pair of towers.It could be a setting issue with the ECU or a Fault with the ECU.Electronic gubbins sure are fun.Steve..
#845 Chris1992
Chris1992
  • 2,022 posts
Posted 28 November 2020 - 08:05 PM
That's a good shout! from what I can see on the coil plug there are 3 wires going into it (green, red, and orange) so how do I tell which ones are the 12 and 34? I've recently had the ECU tested by SC as I wasn't getting any spark at all, and they said they did find an issue which supposedly was resolved, but who knows, I may need to send it back to them again.
#846 sonscar
sonscar
  • 3,249 posts
Posted 28 November 2020 - 09:48 PM
Unplug it and test for 12 v on one of the connection with it turned on.This is the live to both sides.The other wires are 12 and 34.The ECU grounds these wires to spark the coil.Steve..
#847 Udo
Udo
  • 1,670 posts
Posted 03 December 2020 - 11:25 AM
You mean like this:
I've just fitted a brand new k1200 1380 into my car that's been built completely built for me by Specialist Components, but I'm having trouble getting a spark. The plug leads are currently fitted to the coil with plugs 2 and 4 swapped around (this is how they were when the engine was delivered), so I'm thinking that may be wrong for starters. I'm also only getting spark from ignition outputs 1 and 2. Nothing from 3 or 4. Would you say this has to be either a faulty coil or plug leads? Any advice would be much appreciated!  :D
Hi,
Had the same problem of only getting spark on half the coil. Found I'd slightly bent the crank sensor pickup when installing it so it wasn't quite in the right place. Worth double checking this.
Udo
#848 Streetscreamer
Streetscreamer
  • 16 posts
  • Local Club: Mini Seven Club Netherlands
Posted 08 December 2020 - 09:12 PM
Hi there...... this static ignition is using a so-called wasted spark. When piston in cyl 1 is short before TDC and it needs to deliver the spark for combustion, another spark happens in the related cylinder which has its piston also short before TDC. That is cyl 4. So we have two pairs to do the trick: 1 plus 4 and 2 plus 3. How they show be connected to the static ignition coil is a matter of measuring. The outputs can be checked for connection by measuring resistance. Just an Ohm or so will be found while connecting two outputs. This outputs to be connected with the paired cylinders (1&4  or 2&3). If then the engine still does not want to run, simply swap the pairs from position on the coil.
