Bmw 16V K1100 1380 Engine
847 replies to this topic
#826 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 02 July 2019 - 09:18 PM
Very neat, looks better than my arrangement of rubber grommets and o rings! I went simple for the routing of the throttle cable, not sure if it will be a success or not, it certainly functions but it could wear out the cable prematurely, time will tell - if I ever get this thing on the road of course :-)
I've since cut away the front panel for the filter to fit, it is a little tight and an adjustable engine steady certainly helps.
My 90degree bracket to re-position the original throttle cable mount, I may shorten this to bring it further up.....
I also replaced the rubber parts with new, I couldn't find a new breather pipe though and the two I had were both perished, I've simply blocked off the breather entries on the TB's with silicone blanks, but is this a problem and should they actually all be connected up as yours are is the question on my mind now!
Interesting! I was going to go down the grommet route, but could really figure out if it would work. I think it looks great.
Regarding the breather pipe. I figured to hook them all up, nitre really sure what difference it makes if they are linked together or if they are blocked.
#827 alchall
alchall
  • Just Joined
  • 604 posts
Posted 03 July 2019 - 05:45 PM
Thanks, I'm happy enough with how it's turned out, yours just looks a bit less DIY :-)
If I find simply blocking the breather inlets is a bad move it's a simple enough job to replicate your solution...
#828 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 July 2019 - 08:55 PM
ROLLING ROAD session....
120 bhp and 134 Nm
Always a really fun experience. the tuner played around with etc cam lift/timing for about and hour, turns out the best result cam from 1.1mm lift plus approx 3 degrees on the inlet and 1.1mm lift ion the exhaust.
#829 KTS
KTS
  • 2,490 posts
Posted 09 July 2019 - 09:05 PM
nice numbers !
how does the car feel to drive since the tuning session ?
#830 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 July 2019 - 09:44 PM
nice numbers !
 Feels good!
After the big power runs, the tuner actually spent most of the time mapping the car for "normal driving".
#831 mini13
mini13
  • 3,811 posts
Posted 10 July 2019 - 07:24 AM
sounds like a good tuner, a lot just want to get away woth the least work, often hard to get them to look at waggling cam timing
numbers are right where i'd expect for yur spec
#832 IronmanG
IronmanG
  • 1,363 posts
  • Local Club: Box hill. Lsmoc member
Posted 31 August 2019 - 07:05 AM
Thanks for sharing the trials and tribulations. I had written this conversion off but now it's another choice in search of extra power in my own car next winter.
Thanks again
#833 Dracula
Dracula
    Just On Tickover
  • 6 posts
Posted 04 September 2019 - 12:44 PM
Hi Craig
Which tuner did you use?
Thanks Sorin
#834 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 11 September 2019 - 06:34 PM
Hi Craig
Thanks Sorin
Hej Sorin,
I used Svalle at http://tsmotor.com in Åstorp
I have also Marco at BSR Malmö in the past, I understand he has moved to Kävlinge.
Cheers!
#835 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 12 November 2019 - 01:30 PM
Decided to switch over to k1200 throttle bodies. I want really happy with the throttle quadrant solution, as I really had to adjust the "adjustment" screws on the TBS quite a lot.
Seems direct fit to the k1100 head when using the k1200 inlets
#836 mini13
mini13
  • 3,811 posts
Posted 12 November 2019 - 04:26 PM
Yep, the head castings are essentially the same apart from a couple of small differences, the main ones being the oil way meing moved and the addition of 2 bolts for the chain cover.
#837 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 17 November 2019 - 04:24 AM
Looking good Craig, out of curiosity.....where did you get the K1200 throttle bodies from?
Cheers Paul.
#838 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 November 2019 - 07:33 PM
Cheers Paul.
From here - https://shop.mtw.bik...drrsvcmejfdau2
Second time i have ordered from them everything came super clean
#839 alchall
alchall
  • Just Joined
  • 604 posts
Posted 19 November 2019 - 07:53 PM
A UK option, I bought a few parts from here, not throttle bodies though....
https://www.motorworks.co.uk
#840 Midas Mk1
Midas Mk1
  • 5,852 posts
  • Local Club: S.U.N.M.C
Posted 19 November 2019 - 07:56 PM
Im seriously tempted by a K1100... seriously! Love your build!
