Bmw 16V K1100 1380 Engine
847 replies to this topic
#766 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 May 2018 - 08:27 PM
Nice big car meet tonight. I was parked in the new BMW and MINI club section, at first , i was going too move to the European classics section, bit figured I do have half a BMW engine :proud:
#767 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 02 June 2018 - 04:39 PM
Found and removed a brake vacuum pump form a volvox at a scrap yard today.
I was able to salvage the full system, (switch, connectors, vacuum hose, one way valve, loom mounting brakes, and a extra hose from another car) for the grand price of 11 pounds.  I originally had an Audi system, the Volvo pump seems to mount easier.
It seems the Volvo pump is used to assist/top up the engine vacuum. It doesn't come with a  reservoir.  Northernpower has a great write up with an audi pump and uses a reservoir. He (as I understand) uses the pump to as a stand alone pump, I.E not engine vacuum.
I currently do run 4 vacuum hoses from my 4 ITBs, It works, but the level of vacuum is a bit sporadic. I think I can just connect this Volvo system up as it is, keeping my engine vacuum lines also
Wiring wise, its seems it is only a 12V ignition feed and an earth.
Pictures coming soon.
#768 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 02 June 2018 - 04:46 PM
#769 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 03 June 2018 - 09:15 PM
Pump tested and working, I little but noise than i thought.
Polished and painted, not perfect, but not bad for a part from a 10 -15 year old Volvo
I decided the easiest way to mount it would be using the original bracket.
After some modification
Bracket and pump mounted.
Just needs plumbing in and wiring.
#770 Richie83
Richie83
  • 1,495 posts
Posted 04 June 2018 - 07:29 PM
That looks like it’s always been there. I honestly had to Where’s Wally that pump. Good job.
#771 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 04 June 2018 - 09:55 PM
Hopefully  it feels like it is meant to be there also.
We see.
#772 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 June 2018 - 09:17 PM
Vacuum pump all plumbed in and wired. Tried to keep it as neat as possible but there are quite a few hoses and wires, switches, connectors etc.
The brakes perform really nicely now. I now know that I will receive the same assistance from the servo every time.
The pump is a bit noisy, and turns on for a split second when the brakes are applied under normal driving conditions. I feel it will get annoying.
I will look for a reservoir.
#773 stevegrabba
stevegrabba
  • 65 posts
Posted 11 June 2018 - 04:07 PM
I've got an electronic vacuum on my 7 porter running from an ignition live.  However, I'm told that they draw around 15 amps when operating, and I feel that its pulling too much juice/current from the coil pack and ignition.
Occasionally I get an unexpected  blip/drop on the tachometer and it  can cause the car to stall when under low load.  As a result I am thinking of running a fused constant live through via switch and hence taking it off the ignition live.
I'd be interested to know how you get on with your setup?
#774 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 11 June 2018 - 08:35 PM
I keep you updated.
I have wired more in via relay triggered by ign and with a fused live
#775 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 14 June 2018 - 02:20 PM
Little update:
The pump seemed to work fine. But then on one trip it ran constantly, so I had to disconnected it.
In other news - I am a bit sheepish to write this - but I lost it on a corner and planted it down a ditch and into a field. Good fortune means that there is not a scratch nor any damage on the car. phew. Only thing hurt is my pride. Lesson most decently learned  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:
you can see where i went of (skid marks)
And where I ended up - Inches form the fence
On a positive was caught on camera again.
#776 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 June 2018 - 05:19 PM
#777 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 28 June 2018 - 05:37 PM
Car is looking very smart Craig, are you taking it over to Bristol next year?
#778 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 June 2018 - 08:15 PM
Cheers!
I might just come to Bristol, just noticed that the dates are later than usual, which suits me perfect.
#779 nicklouse
  • 18,523 posts
Posted 28 June 2018 - 08:19 PM
you can almost read their speech bubbles in those photos.
#780 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 June 2018 - 10:09 PM
I like the one with the wife giving the husband a hard time!
