Bmw 16V K1100 1380 Engine
847 replies to this topic
#751 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 03 May 2018 - 08:40 PM
Nice work, wait until you drop a bolt or nut in the gravel  :D
Done it already!  :shy:
#752 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 12 May 2018 - 07:46 PM
Nice little trip over the Oresund bridge and tunnel to Copenhagen today.
Did I say Tunnel:
#753 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 14 May 2018 - 08:36 PM
Caught on camera at a car show
#754 Psycho-biker
Psycho-biker
  • 91 posts
Posted 14 May 2018 - 09:29 PM
Did I say Tunnel:
THAT NOISE!!!!        Tissues please!!!
#755 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 17 May 2018 - 11:47 AM
I have never been satisfied withy my speaker set up. I have two 6x9s in them parcel shelf and i had two cheapo small 4.5" under the dash, pointing to the floor. Could hardly hear the fronts.
So i have been on the look out for a low cost solution. I found a set off Pioneer pods with speakers at a auto jumble for a whole 40p. Painted them up and mounted then under the dash. I have actually only bolded them through the career and sound deadening with a spreader plate at the rear. The paper to be held fairly secure.
I am quite happy with the result and sounds good too!
#756 alchall
alchall
  • Just Joined
  • 604 posts
Posted 22 May 2018 - 02:30 PM
Thats great! I will do something similar. The VW/Audi pump looks smaller than the Volvo pump
Never even thought of reservoir. DO you have apart number or supplier for the switch
This is for the switch. https://uk.rs-online...235393636333226
I've started turning my attention to this, and I noticed that the switch at the end of the link says it's rated at 250V AC - did you get this very same version, assume if you did that it works on the 12v system?
#757 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 22 May 2018 - 02:47 PM
Yes I did, it's fine at 12v.
#758 Richie83
Richie83
  • 1,495 posts
Posted 22 May 2018 - 05:44 PM
Whats going around the vent? Is it a map light?
#759 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 May 2018 - 07:56 AM
yip a wipac map lamp
#760 alchall
alchall
  • Just Joined
  • 604 posts
Posted 23 May 2018 - 09:44 AM
Great thanks, that's good to know!
I can't find any good information about how the pump should be wired up, don't suppose you have a little diagram of how you wired your system up do you?
#761 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 23 May 2018 - 06:51 PM
I've decided to bin the servo, and fit the KAD brake bias setup.
#762 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 24 May 2018 - 08:15 AM
I've added a further entry to my thread for the wiring http://www.theminifo...cuum-generator/
#763 alchall
alchall
  • Just Joined
  • 604 posts
Posted 24 May 2018 - 08:23 AM
Fantastic, thanks for your help!
#764 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 May 2018 - 08:33 PM
I have never been totally happy that the fuel lines were hanging over the manifold. I found a nice silicon/glassfibre cover on fits nice (shiny hose at the rear). I also have a set of tea strainers fitted for a cars show tomorrow.
Finally stuck on a set of numbers
#765 nicklouse
  • 18,524 posts
Posted 28 May 2018 - 08:48 PM
tea strainers are good for shows. keeps most things out of them.
