Bmw 16V K1100 1380 Engine
847 replies to this topic
#61 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 31 May 2016 - 09:49 PM
Maybe I try and hold the cam pulleys with this tool, while I tighten the bolt
Screen%20Shot%202016-05-31%20at%2023.40.
#62 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 04 June 2016 - 08:39 PM
Cam bolts on torqued up now.
I am now thinking about which air filter to use.
individual cone filters will work, but then you can use the ram pipes.
So I am looking at domed foam panel filters from ITG and Pipercross (piper cross being half the price)
I know SC sell a domed ITG filter.
However, I am struggling with the throttle cable bracket, since it seems it will be in the way of most filters.
FC52F6BF-5DC5-4C5A-BA43-46CB74E6D1AC_zps
#63 nicklouse
  • 18,562 posts
Posted 04 June 2016 - 08:58 PM
Leave it till the engine is in the car. As there is bonnet issues to consider as well.
#64 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 June 2016 - 06:43 PM
Yip I think that is the safest option.
this looks like a candidate though
Screen%20Shot%202016-06-05%20at%2020.41.
#65 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 June 2016 - 07:23 PM
Having a bit of trouble working out the wiring. In particularly the SPI really packs
I have them on the bench. Basically, it is a separate loom with the main black really box, one of the yellow relays and the connecter which sits beside the yellow really.
This loom had a couple of the old  ECU sensors and a I guess a 12v feed.
All the old ECU parts have been cut off, leaving a wire from the main really for the O2 sensor and a wire from the yellow really for try O2 sensor. Can i just remove these from the relays? I assume this won't effect any thing thing else?
#66 Richie83
Richie83
  • 1,495 posts
Posted 05 June 2016 - 08:29 PM
That K&N looks mega. I've got ITG sock filters on mine, but they are ripping. This might be an option. Have you considered a plenum chamber?
#67 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 June 2016 - 08:52 PM
I have, though I haven't really been able to source one. I think ITG do a nice plenum.
Yip that K&N looks great, though I dont think you can use the ram pipe
#68 Richie83
Richie83
  • 1,495 posts
Posted 05 June 2016 - 09:00 PM
did you know SC make one? I do like the K&N though, I may go down that route.
#69 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 June 2016 - 09:02 PM
I knew that - i would like a cheaper option :shy:
#70 Richie83
Richie83
  • 1,495 posts
Posted 05 June 2016 - 09:27 PM
agreed, I think the K&N route would be a great solution. Will look and sound brilliant.
#71 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 07 June 2016 - 08:49 PM
Looking at the engine breathers.
I plan to use the normal crankcase breather with a breather filter on the top.
However there also seems to be a breather on the rear on the oil drain box, where does the breath to.
Also on the cam plate there is a large outlet (oil from the oil drain box) but there is also a smaller outlet just above the larger. anyone know what this is?
600CFA72-9B37-4C55-9E99-6529CE59FFE7_zps
#72 mini13
mini13
  • 3,810 posts
Posted 08 June 2016 - 02:02 PM
were you not given the breather infor from SC??
#73 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 08 June 2016 - 02:16 PM
I have their build guide, but it states very little.
Basically says a breather is needed on the oil drain box, but no more details.
I will check again later but I don't think the guide even mentions the the smaller outlet on the cam plate.
Or did you mean other info?
#74 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 08 June 2016 - 03:59 PM
The large outlet on the front plate connects to the rear drain box via 3 x 90 deg hoses and straight joiners. I do believe that SC now do a one piece hose. The smaller hole on the front plate vents to preferably a catch tank, but worth while checking regulations.
Andy
#75 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 08 June 2016 - 06:35 PM
Andy
Cheers Andy!
I have the hose kit for the large oil outlet and also the lower radiator hose. Seems like at 85 pounds it was a bit of a bargain and time saver.
would the catch tank also connect to the breather outlet on the oil drain box?
    Facebook (2)
