Bmw 16V K1100 1380 Engine
847 replies to this topic
#676 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 04 October 2017 - 05:25 PM
I guess this was the issue with the broken pulley. The half circle key wasn't sitting correctly. It was also seized like that. I remember it being like that when I first fitted the pulley. I didnt know that the key was a separate part, so I just assumed that is how it should be. Didnt actually think much about it.
Just for the "belt and suspenders" minded like me, I would clean the end of the shaft thoroughly and then put a couple of drops of oil on it and on the key to ensure that the pulley makes it all the way in.
#677 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 October 2017 - 07:41 PM
So back onto this! I have had a hectic couple of weeks full of teaching, but time to get back to this. I ended top send the pulley back to SC and they secured the ring on.
I refitted the plate and the new seal, with a smear of RTV around the CAM and keyway (just in case)
The pulley is on and I will retime the cams this weekend. I am sure they haven't moved and I did mark the crankshaft position etc. But it doesn't take that long to do so I will just start from scratch. Originally I had them timed with 1mm of lift, then after some advice from the 16v mini Facebook page i timed them with 2mm of lift. This improved the responsiveness but I felt I lost a little of the low down power, I have decided but this time I maybe set them at 1.5mm. I think about it,,,,
In the mean time, with the weather drawing in, I have started to make some of the "retro" looking signs for my garage dress-up.
I bought some MDF letters from eBay to allow me to knock this up.
#678 timmy850
timmy850
  • 3,314 posts
  • Local Club: MITG
Posted 20 October 2017 - 11:08 PM
Hopefully you can get it all sorted quickly.
Your sign turned out really cool! I wonder, could you put a row of strip LED's on the inside of the frame to light it up at nighttime?
#679 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 October 2017 - 08:15 PM
I thought of that, but I have some other ideas for illuminated signs.
#680 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 October 2017 - 08:19 PM
Garage sign number 2.
Bought 2 decals online, stuck them and sandwiched them between some perspex. Built a wooden frame, added to LED strip lights and clad it in stainless (used for edging glass bricks).
Pretty happy.
#681 imack
imack
  • 2,099 posts
Posted 25 October 2017 - 08:22 PM
Loving the bmc service sign, what sort of size is it?
#682 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 October 2017 - 08:23 PM
Thanks!
600 x 400
#683 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 07 November 2017 - 08:22 PM
Almost back together -
And the cam cover is back on. Maybe get it together next weekend, then take it for an MOT.
In the meantime I have continued my garage project. Neighbor asked me if I was opening a garage  :shy:
Gonna lay a wooden deck next.
#684 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 11 November 2017 - 09:51 PM
If I was driving past, I would certainly pop in for an engine service
#685 zeemax89
zeemax89
  • 129 posts
Posted 14 November 2017 - 12:21 PM
Loving your thread.  I have a 16v head ready to begin work.  But first I need to finish the bodywork.
You mini has exactly the stance I an looking for on 10" wheels.  I have purchased some group 4 arches. Can I ask what arches you are running?
Finally got round to applying some door roundels
A7B49E5E-1D8C-41CF-9976-ACA2B40A0F90_zps
40D531A7-21F5-4823-9D10-72BBDF8AC4E6_zps
1DEDACE9-1801-4A75-B9D1-5CFD7AC8F78B_zps
#686 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 14 November 2017 - 10:19 PM
The arches are called "bullet" arches, the were fitted on the car form the factory/dealer.
 The stance is helped by the large offset wheels ( ET-15)
#687 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 26 November 2017 - 09:44 PM
Hi Craig, love your garage signs, did you get your engine running again, just wanted to find out if you noticed any difference in performance after altering your cam timing, as I'm getting close to fitting the engine into my car. Just wanting to find out, as it's easier to do everything out of the car!
#688 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 November 2017 - 01:30 PM
Just need to get the radiator/fan/coolant back in and the car is good to go.
Regarding the cam timing I started with 1mm of lift, the car produced good power and torque (this was the figured recommended by SC). Consensus however among the other twin cam guys was 2.4mm of lift, which is what the k1100 would have had. I retimed to this figure and the only difference I could feel was that the power/torque band had moved up the rev range. Whether that is correct or not I don't know that is what it felt like.
I retimed the cams a couple of weeks ago, I actually just set them to half way between 1mm and 2.4mm (1.7mm) of lift. We see if that makes any difference. I feel now that I have timed the cams a couple of times, It is actually pretty quick to redo it (an afternoon maybe).
#689 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 30 November 2017 - 06:42 PM
Regarding the cam timing I started with 1mm of lift, the car produced good power and torque (this was the figured recommended by SC). Consensus gower among the other twin cam guys was 2.4mm of lift, which is what the k1100 would have had. I retimed to this figure and the only difference I could feel was that the power/torque band had moved up the rev range. Whether that is correct or not I don't know that is what it felt like.
Cheers Craig, I think I will start at around 1.5mm lift on both cams to see where the power is, don't want to be revving the hell out of her, and I would prefer the power band to be lower down, makes it better for driving on the road.
#690 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 03 December 2017 - 11:19 PM
Still haven't got this back together.
I had to replace the springs on my Audi over the weekend. I noticed the car had sank on one side and was shocked to see the spring had snapped.  zfmiNYh.jpg
Not the nicest Job in 1 degrees. Anyway, I managed, was pretty straight forward, thanks to my Goliath of a spring compressor.
Local garage quoted me 350 quid to replace both springs, so I thought I would give it a go.
Maybe the mini will get done next weekend.....
