Bmw 16V K1100 1380 Engine
847 replies to this topic
#631 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 20 August 2017 - 09:19 PM
Ever wished you went forced induction?
#632 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 20 August 2017 - 09:25 PM
You mean instead of the 16v?
Would never have got it through a registration inspection.
Saying that I have looked into what can be done in the future with this set up
#633 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 20 August 2017 - 09:47 PM
Really? Bummer. What's the law over there. My supercharged set up passes a modern cars emissions level on an mot.
#634 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 August 2017 - 07:10 PM
Finally got the seal out, seal looks fine with no notable damage.
However perhaps the issue was that the seal almost blocks the oil drain channel.
#635 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 August 2017 - 07:29 PM
SO I have a new seal fitted in the cam plate and have filed the part of the seal which was blocking the drain channel.
Just as I went to fit it, i noticed that the oil drain hole isn't real a hole on the block side.
I guess that this is how it should be.......
The smaller of the holes is for the bolt.
#636 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 August 2017 - 09:36 PM
W t f ?
#637 mini13
mini13
  • 3,810 posts
Posted 28 August 2017 - 09:27 AM
Isn't there a slot on the back of that plate that goes to the breather hole.
#638 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 August 2017 - 09:38 AM
There is a slot in the round plate.
Do you mean there should be a slot in the larger engine plate also?
As you can see the behind the larger hole is in fact just the block, do you mean there is a slot there also?
#639 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 August 2017 - 09:54 AM
There is actually a slot on the back side of the large engine plate. panic over....
#640 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 September 2017 - 07:04 PM
Not sure if anyone os still following this. It is a bit doom and gloom  :nuke:
Struggling to find time with the new school term starting. I managed an hour or so tonight, I refitted the cam plate and seal etc. I replaced the cam shaft "triangle plate" as the one which came out was well worn. Not sure if it matters, but i changed it anyway.
Then I went to refit the layshaft pulley and noticed it had split....
A bit concerned about that. I think it might damage the oil seal is it is. Maybe that is the cause of the leak?
#641 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 05 September 2017 - 07:07 PM
You're not having an easy ride with this Craig. Is that an SC part?
#642 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 September 2017 - 07:19 PM
I know! Yeah it is the SC pulley.
Not sure whether to fit it or not. I asked on the twin cam mini Facebook group and that part butts top against the triangle plate so shouldn't be an issue. but unsure.
#643 nicklouse
  • 18,562 posts
Posted 05 September 2017 - 07:21 PM
but where does the seal sit?
#644 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 05 September 2017 - 07:22 PM
Everyone will have an opinion, mine is, I'd change it. Ring John and ask him if he'll do you a deal.
#645 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 September 2017 - 07:26 PM
