Bmw 16V K1100 1380 Engine
847 replies to this topic
#586 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 02 July 2017 - 06:15 PM
Why ca,nt i see the photos on the pages they have photo bucket on them and when i click on it and go the page,nothing
http://www.theminifo...on-photobucket/
That's gonna affect alot of forum sites. Toss**s
Edited by HUBBA.HUBBA, 02 July 2017 - 06:16 PM.
#587 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 02 July 2017 - 07:28 PM
Yeah it is a right pain.
I will at one point go through this thread and post the pics again.
#588 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 04 July 2017 - 01:21 PM
How's the cam seal repair coming on?
#589 nicklouse
  • 18,562 posts
Posted 04 July 2017 - 02:08 PM
he might be having a beer or 1/2 as he has been "promoted" at work.
#590 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 04 July 2017 - 03:35 PM
:D  :D  :D
#591 Mrstars11
Mrstars11
  • 192 posts
Posted 07 July 2017 - 11:47 AM
@minisilverbullet  hows the engine coming along?
ive had to cut the inner wing in order to get a switch controlled electric fan in alongside the rad, tried without cutting it out and the blades were fouling on the rad core.
but once thats done and wired i think its all done.
it got mapped and rolling road tested yesterday, but they called to say it hadnt hit the drop on the power curve at 7500 rpm, and did i want to risk the crank and push it harder or leave it. so i left it.
just out of curiosity, what crank do you have in yours? standard or strengthened im scared to push mine past 7500rpm on the standard crank. also where abouts rpm wise did yours top out on power?
#592 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 July 2017 - 08:11 PM
I am running the standard crank (balanced). Specialist components have hard limited the  the RPM to 7200. What camshafts do yo have?
#593 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
SO I spent the last 2 weeks "fixing" that. and degreasing the engine bay as the cam belt had sprayed oil everywhere.
I started it up this evening to be welcomed with the sight of oil spraying from cam belt again.
I now think it may actually be the seal on the lower fully (old camshaft position).
#594 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 09 July 2017 - 10:08 PM
SO I spent the last 2 weeks "fixing" that. and degreasing the engine bay as the cam bale had sprayed oil everywhere.
Oh no, I feel for you.
#595 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 July 2017 - 11:12 PM
HAHAHA!
I just saw this! Indeed! I need a beer not to celebrate but to calm my nerves with this engine.
#596 nicklouse
  • 18,562 posts
Posted 09 July 2017 - 11:27 PM
this new leak is it high pressure or just a seep that is then doping on the belt?
not much pressurised on that side on the standard mini unit.
#597 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 July 2017 - 09:36 AM
Yeah it isn't high pressure it is seeping heavily from somewhere ( I think the old camshaft)  and onto the belt.
#598 nicklouse
  • 18,562 posts
Posted 10 July 2017 - 10:34 AM
so from the timing chain cover or seal.
you need to get under and give it all a real good clean to check that the half moon seal between box and block is not the issue. I would not think so this early on.
Edit: forgot that there was a ´new cover for there.
Edited by nicklouse, 10 July 2017 - 11:25 AM.
#599 nicklouse
  • 18,562 posts
Posted 10 July 2017 - 10:35 AM
just thinking when you were re doing the timing disc you may have dislodged/damaged something.
#600 mini13
mini13
  • 3,810 posts
Posted 10 July 2017 - 10:57 AM
the seal on the (old cam) seals onto the SC pully, so check that oils not getting up the key way and out that way.
