Bmw 16V K1100 1380 Engine
847 replies to this topic
#526 nicklouse
  • 18,562 posts
Posted 25 March 2017 - 07:36 PM
Whould have been better in white rather than old English white.
#527 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 March 2017 - 08:09 PM
You think! I think it is more retro looking with the OEW
#528 nicklouse
  • 18,562 posts
Posted 25 March 2017 - 08:37 PM
So you are reprinting the roof and painting the bonnet?
#529 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 02 April 2017 - 06:24 PM
Finally got round to approaching the idea of having a removable panel at the front of the bonnet to cover some holes, i have yet to cut.
Arc Angels sorted me out with a panel from the same mould as their 16v bonnets.
A96C988C-06E3-4A05-9EDA-18AFCB00EBD5_zps
I spent some time shaping the panel, I have some rubber trim to go around it, but I think i need something with a thicker "slit".
80F035EC-BC3A-4638-BD0E-C8E135758F4C_zps
These are the shape of the holes I intend to cut. And i will attach the panel with some sort of 1/4 turn fitting on each side.
78340815-4870-4624-8E2B-9591E9756F8C_zps
#530 Simon998
Simon998
  • 74 posts
Posted 03 April 2017 - 12:32 PM
Could you not make that into a hinged flap?
Run a hinge along the top and then when you want to open it, open the bonnet, flip the flap up and fasten it to the underside of the bonnet.
#531 mina08
mina08
  • 255 posts
Posted 03 April 2017 - 04:40 PM
leave them open and put some wire mesh sprayed white behind the holes
#532 McMini 22
McMini 22
  • 289 posts
Posted 03 April 2017 - 09:34 PM
+1.
Or silver if you are spraying the bonnet to match the car obviously.
#533 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 07 April 2017 - 10:11 AM
+1.
yip spraying the bonnet and the new panel
#534 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 09 April 2017 - 05:30 PM
Why are you having a removable panel. Out of interest
#535 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 April 2017 - 05:53 PM
Just so I can add it when its raining etc.
#536 mini13
mini13
  • 3,810 posts
Posted 09 April 2017 - 06:12 PM
a bit of water shouldnt hurt, free water injection.....
#537 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 09 April 2017 - 07:14 PM
 Isn't really the water I am bothered about, it is all the muck that comes with it :)
#538 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 April 2017 - 05:26 PM
So throttle cable snapped 4km from home tonight (luckily).
Seems to have snapped right at the nipple, it was this part which was resting against the peddle/throttle locking clip.
FD604468-D9C0-487B-8C9D-D38D45D450D8_zps
Being only 4km from home, I thought I could manage home by just rating the idle speed and driving. I had to snap an umbrella handle and squash it flat, so I could use it as a flat head screw driver. It was slow and I almost made, but I was conscious of a couple of hilly parts.
Being an unsociable git, I don't have anyone nearby to ask to give me a hand. So I decided to lock the throttle slightly open, by tying the remainder of etc cable to the spot lamps.
C961EE9A-64C9-4897-B976-A27DD1CE0373_zps
Long story shorty made it home MacGyver style.
Now to look for a new cable, but more importantly try to think how I can stop it happening again.
An ideas?
#539 mini13
mini13
  • 3,810 posts
Posted 10 April 2017 - 05:30 PM
Sounds like the niple is rubbing the cable, try chamfering it a bit, or maybe drilling it out a little too
#540 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 April 2017 - 09:16 PM
I think it has rubbed on the retaining clip.
Maybe I overtightened the bolt on the nipple?
haven't really thought of a solution other than putting a adjustable nipple/connector each side of the retaining clip, to stop the cable moving.
