Bmw 16V K1100 1380 Engine
847 replies to this topic
#481 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 December 2016 - 06:13 PM
Good stuff,
It's good to have it a bit lean for running in, well not rich anyway... So that's probably why the map is biased that way.
I'd was going to say I'd expect a bit more power than that, but the I saw its at the wheels, so about where I'd expect it!
I found it worthwhile moving the car cam timing from SC's recommendation, but that was on an 8v.
The cam timing was pretty good, I cant remember exactly the figures, but the build guide stated 1.6mm of lift, but after speaking to SC they recommended that 1mm of lift was better.
#482 mini13
mini13
  • 3,811 posts
Oh and regarding the losses, some rollers can do a back measurement to get a figure from them.
20% is a bit simplistic, but it's about what I'd expect in this instance, so your making high 120s
I think 20 hp rather than 20 % is generally more realistic,
#483 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 December 2016 - 02:42 PM
Yip in this instance 20% and 20hp are almost the same.
#484 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 December 2016 - 12:03 PM
And now for a Vid which is the correct way round  :shy:
#485 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 04 January 2017 - 02:26 PM
I am thinking of putting some holes / ovals in the front of the bonnet. Both for airflow into the ram pies but also aesthetics.
I guess the engine bay will get pretty dirty?
I wonder if there is a way I could have a removable panel for wet days?
#486 mina08
mina08
  • 255 posts
Posted 04 January 2017 - 02:45 PM
Why not a deflector scoop coming up from the top half of the grill, easy to make with a sheet of aluminum?
#487 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 04 January 2017 - 02:50 PM
It'll be a rough percentage as its linear to the drag co-efficiency of the running gear throughout the rev range. 20% for a mini is high! Considering on most 4wd systems its usually between 18-22%.
#488 ajperry
ajperry
  • 316 posts
  • Local Club: Thames Valley Mini Club
Posted 10 January 2017 - 12:13 AM
Just read all the way through. Couldn't put this down!
Glad everything has turned out ok after your back and forth with the wiring issues.
Really inspiring and a great amount of information as this exactly what I'd like to do in the near future.
Top thread!
#489 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 January 2017 - 08:57 AM
Top thread!
Many thanks!
#490 mini_nutz
mini_nutz
  • 117 posts
Posted 12 January 2017 - 09:51 PM
Looking good, reminds me when i completed my build back in 2010.
#491 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 12 January 2017 - 10:07 PM
I read your thread many times!
#492 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 18 January 2017 - 07:54 PM
Hi Craig, been looking through your thread again, it been great for helping me out on some of the problems that I've come across. I'm at the stage of fitting the ignition coil pack but SC haven't marked the firing order on the coil pack, I noticed that you did a drawing, but was that OK, and where the ignition leads put on the normal A-series firing order sequence. Here's a cheeky wee upside down picture of my engine, bloody I-pad!!
#493 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 January 2017 - 09:11 PM
I promise to get a drawing this weekend, if that alright.
#494 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 20 January 2017 - 12:21 PM
I think this is very cool! Many thanks to Stickyfingers.
6A4A7544-80EC-4199-9E1C-F892636CA493_zps
#495 nicklouse
  • 18,689 posts
Posted 20 January 2017 - 12:27 PM
they do do great work.
