Bmw 16V K1100 1380 Engine
847 replies to this topic
#31 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 03 April 2016 - 07:56 AM
I bet you can't wait for the motor to arrive.
#32 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 03 April 2016 - 08:28 PM
Cannot wait! enough to keep me busy in the mean time.
#33 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Trying to tidy up my wiring today.
it is a bit of a mess, it has been retro fitted with additional wiring for DLR lights. which i will have to keep. I haven't quite got my head around it yet, but as it seems: looks like the original light wires run into a double relay, they really also connects to the starter and the alternator.
Also I have seen pictures of the SC conversion and they have retained the SPI/MPI really packs, is that the case? or I was I dreaming?
#34 nicklouse
  • 18,541 posts
Posted 03 April 2016 - 08:35 PM
You can have the DRLs on a switch or even just have the wiring as normal and you turn your dip lights when driving.
I got man a flash when I had forgotten to turn them on.
I would not be too concerned.
#35 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 03 April 2016 - 08:37 PM
Maybe it will be simpler to return them to normal.
When I had the car in the UK I was flashed all the time for having my lights on. Was sitting at a set of traffic lights and a guy knocked the window to tell me my lights were on.
#36 nicklouse
  • 18,541 posts
Posted 03 April 2016 - 08:38 PM
It is what I would do. Then then it is all sorted look to get them sorted for nordic driving.
#37 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 April 2016 - 09:00 PM
High flow cats -
I understand that there is a slight performance benefit, but is there any emissions benefits?
#38 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 06 April 2016 - 08:24 AM
If you look at the specs a lot of the high flow cats they have a cpi (cells per inch) of 100 or 200 which gives then greater flow but gives less time and surface area for the cat to do it's job, the guy tuning my conversion was suspicious of any aftermarket cat. OEM cats are generally around 400cpi depends on what spec ie euro 2, 3, 4.
#39 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 April 2016 - 08:55 PM
Spent the afternoon cleaning and degreasing the engine bay.
Took a bit of time and a whole pile of clothes, brushes and rags, but turned out alright (i think)
Also gave the subframe fresh coat of paint.
4C854BF3-727D-40DB-8F92-1A8AA9DEADB0_zps
3f248b0a-e673-46c5-88bd-94f16858abc4_zps
#40 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 12 April 2016 - 11:49 AM
Short block and ancillaries arrived with Guessworks for the gearbox, med flywheel and clutch assembly to be "bolted" on.
#41 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 12 April 2016 - 10:06 PM
Alloy "chinese" radiator arrived today, after my initial inspection i was fairly impressed with it. However the cowling didn't fit over it, it fouled in various places. Meaning the bolt holes would never line up.
D274CAD0-0916-489A-A3A9-71EFE0C56E20_zps
D6920D06-526B-4DE7-BD99-2D298C76434C_zps
0183FE6C-5D62-4758-8CA9-455FB65B45A6_zps
I was felling brave, so I set about the cowling with my new angle grinder. First time I have ever used one (so i was fairly cautious)
removed the top lip:
33B83D6E-DCF5-45D3-8AB4-3F7E9A9E758C_zps
D1AD2DEB-27B3-4CF5-88E4-F33F4F774026_zps
trimmed around the corners:
DF2A70FE-B68C-471B-A7CA-D783248EFE76_zps
BC635EAA-49E1-4974-9D3C-39E8D31EFCA7_zps
And…….
2FD1DB39-AFCC-4011-BD78-E857668A1BDC_zps
49F4C40A-0716-4666-93BE-96C2D270120A_zps
Hopefully there is enough clearance for the fan…...
#42 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 May 2016 - 08:05 PM
Well it arrived…..
38FBD1B4-2237-4F3D-BEFE-897523656014_zps
F90C422D-74DA-450F-8C2A-A87C9453AE1E_zps
00917199-440B-4336-9134-8549DC4BDF7B_zps
A261C9A5-DD16-42FD-86BE-92AD27383822_zps
8896E41A-3352-4733-9099-A9B78EC33954_zps
42794780-01C2-4C43-A8D1-1C7BA4120BF4_zps
C385CAFB-61D0-4AF2-B82D-4BAE0B541663_zps
E9AE6512-ADF7-4451-A11D-CD4185ECB2A0_zps
7EC4DFB1-F108-40DB-8C73-25CD687F4A40_zps
F196FDBA-3F42-49F4-A991-487CAB25E241_zps
#43 Alex_B
Alex_B
  • 4,573 posts
Posted 26 May 2016 - 09:53 PM
How long did it take to arrive ? I am looking to order next month I recon and was curious on lead time. But it's looking good and a pile of shiny bits like that are hard to beat!
#44 leaky
leaky
  • 6,890 posts
Posted 27 May 2016 - 07:44 AM
Looks good, I'd also be interested on lead time as I am getting really tempted by this kit!
#45 Richie83
Richie83
  • 1,495 posts
Posted 27 May 2016 - 07:46 AM
Looks ace. I like the oil filler on the cover.
