Excellent progress! Sounds so much better with a 16v head on.
Bmw 16V K1100 1380 Engine
#331
Posted 13 August 2016 - 05:12 PM
#332
Posted 13 August 2016 - 07:36 PM
Still a bit stumped by the coolant sensor.
It is functioning correctly, given the live data on the laptop.
But the gage raises to the red when the ignition is turned on.
Question - does the gauge actually take the temp from the coolant sensor (on any fuel injected mini)? or is it from the plug at the bottom of the radiator?
#333
Posted 13 August 2016 - 08:26 PM
The sensor on the rad is the fan switch! Coolant sensor on injected minis is in the inlet manifold. Very neat job you've done. Will be keen to see what Bhp you're going to get. We went for the micra conversion because were cheep! lol
#334
Posted 14 August 2016 - 07:57 PM
#335
Posted 14 August 2016 - 08:09 PM
Its only there on the SPi. Its on the thermostat housing on the MPi. On injected minis, the ECU gives the gauge the signal.
#336
Posted 14 August 2016 - 08:14 PM
#337
Posted 14 August 2016 - 08:28 PM
Quik Latch pins? They look mega.
Yip!
#338
Posted 14 August 2016 - 08:39 PM
I've got some mini ones for something I'm planning. I used the locking ones on my carbon load bed. They're mega.Yip!
#339
Posted 14 August 2016 - 08:42 PM
Yip!Quik Latch pins? They look mega.
It is the mini ones I have used, The larger ones look real big. I think about 65mm in diameter).
The locking ones seemed a bit pricey.
#340
Posted 15 August 2016 - 07:56 PM
So throttle cable finally working flawlessly.
So went for a short spin, It is as fast as I had hoped. But I will need to check the actual speed on a gps, because it felt like I was gong faster than the speedo showed (could just be me).
I have contacted the inspector to come and see the car as soon as he can.
Noticed some small things, which seem to have broken since the start of the build, (indicators and the hand brake aint quite right yet).
Will call SC tomorrow and ask about the temp gauge.
#341
Posted 15 August 2016 - 07:57 PM
FS
#342
Posted 16 August 2016 - 03:22 PM
This is awesome, so glad to see it running and to see you are happy with it.
I have ordered the same arc angels bonnet after reading this thread, figured if i order it way before i need it, it should be here in time for when the twin cam is in, started work on mine yesterday, started stripping the old 998 apart to lift it out the engine bay. My 8v twin cam is very close to being ready also, just a couple of things to finish off on that.
I think i am also going to invest in an electric rad it seems the engine will benefit from having one, and pretty much every twin cam thread ive come across has one.
Your issue with the temp gauge is interesting as mine does the exact same thing now, if i switch ignition on it goes right off the chart within about 3 mins, my top reading is 180 degrees. I have also been told its an earthing issue so i will check that when i get to the wiring.
Really looking forward to seeing what kind of power this makes as i feel like im only a few weeks behind you myself, so seeing how this does may spur me on a little.
especially as yesterday was a disaster day as far as progress is concerned.
thanks for such a detailed thread.
dom.
#343
Posted 16 August 2016 - 03:30 PM
Looks good, based on a scary experience and take this as friendly advice take care with the front bonnet pins I had a pair pull through the inner wings on the outside lane of the motorway at high speed.
TP
#344
Posted 16 August 2016 - 04:58 PM
TP
I saw similar incident on a kit car being driven on a track day. I know they don't look as neat but that's why I fitted the aero catches because they give a much great surface area. If you stick with the pins, I suggest you bond a reinforcing piece (something like 1mm aluminium) on the reverse side of the bonnet and carry it right down to the leading edge so you don't end up with the airflow getting under it and levering it up..
#345
Posted 17 August 2016 - 09:01 PM
TP
I will also fit some leather straps to the front of the bonnet.
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
