Bmw 16V K1100 1380 Engine
#286
Posted 01 August 2016 - 08:55 PM
The trick is to make sure you hit full throttle with the pedal on the floor (or just very slightly off). Anything else and you'll be straining the cable, clamps and linkages to the point they'll fail.
#287
Posted 01 August 2016 - 09:20 PM
I always set mine with a bit of free pedal.
Yip that is how it is now. thanks for confirming that
#288
Posted 01 August 2016 - 09:22 PM
Seems like your cable is binding somewhere. There shouldnt been any play as long as the cable is seated properly in the pedal and throttle body, the throttle should snap back crisply. I had a lot of binding in the cable when i put mine in, spent a long time making sure everything was clear and routed as cleanly as possible. Check how the throttle returns without the cable fitted, and aim for that with the cable on. The BMW bodies i had needed the return springs replacing as they didnt return well enough, and poorly they only have 2 springs for the 4 bodies.
Andy
Hi Andy, they spring back really well without the cable, so as you say it must be binding somewhere.
#289
Posted 02 August 2016 - 07:39 PM
Andy
I have been messing around trying to find a way to route the cable to stop any tight angles. I have it positioned as good as i can get it.
I guess it would be better with a RHD car.
At the moment I have it running over the top of the cam cover
#290
Posted 03 August 2016 - 07:24 AM
Andy
#291
Posted 03 August 2016 - 08:17 AM
Cycles have had many solutions made for them over the years where tight bends are needed in the gear cables.
have a look at the Avid rollamajig they come in different colours.
#292
Posted 03 August 2016 - 08:42 AM
I tried to buy one a couple of years ago, are they still available?
#293
Posted 03 August 2016 - 08:54 AM
there are others available if they have been stopped.
#294
Posted 03 August 2016 - 08:45 PM
Great advice guys!
In the end I went for the V brake attachment (called a noodle apparently). I bought a couple of designs. One which actually goes over the top of the existing cable housing, seems a smart solution (if it works).
The gear cable solution: reading some posts on bicycle forums, I understood that these should not be used on bike brake lines but are suitable for the gear cable ( i guess it is to do with the amount of movement in the cable, but that is a guess). I figured that would also apply to car throttle cables. I try the "noodle".
Thanks again for all the help guys.
#295
Posted 03 August 2016 - 08:55 PM
The force in a throttle system is way less.unless you don't have a pedal stop. Which is a good idea so as not to over force the throttle shaft(s).
#296
Posted 05 August 2016 - 03:25 PM
Hi,
I'm new to this forum and actually probably an imposter as I'm looking at installing the BMW k1200rs head onto a Marina A+ block installed in a Bugeye Sprite in in-line configuration, not transverse. Whilst I do love Cooper S Minis, I've had my Sprite "under construction" for almost 40 years and have it almost ready. I'm just looking to maybe "soup up" the performance with a twin cam.
May I commend you on an excellent, very detailed thread of the challenges you have faced and the solutions all the contributors have provided. This forum is terrific and most helpful. It would appear that the "Build Guide" is not quite as comprehensive as one would expect.
I have a couple of questions : was the provision of parts from SC in "dribs and drabs" due to you receiving them as you paid for them, or because SC were slow to supply them to you and sent them in batches ? I'm in Sydney, Australia and have been really peeved at the slow provision of the Build Guide from SC. I'm hoping this is not an indication of things to come when dealing with them. I guess they were winding down for the Northern Hemisphere Summer break... I don't want to bad-mouth them unfairly. I'm just looking for some independent views from those who have experienced their service.
Also, what amount of deposit were you required to provide SC to get the job started ?
#297
Posted 05 August 2016 - 03:48 PM
Hi,
I agree this forum is great, I certainly could not have progressed through this build without it.
I paid in full for the kit and the build of the short block. It was the build of the short block which delayed the despatch of my kit.
The extra parts that arrived later were due to errors. The wrong loom sent out, missing fuel regulator, incomplete terminal on the new loom. SC dealt with these issues really promptly.
As you say the build guide wasn't as detailed as i needed, but might be enough for more advanced readers. It seems the guide was written some years ago. One thing which I felt let down by was the the misinformation in the guide regarding the cam lift. in the guide it states 2mm, but after specking to SC it turned out they had updated this and that the cam lift was only 1mm, This meant I had wasted a day timing in the cams with outdated data and another evening cleaning all the parts of sealent.
I would say they for the most part they have been extremely helpful. It is useful to remember they are only a couple of guys so they are often busy, so it helped me to be keep this in mind and be a little patient.
#298
Posted 06 August 2016 - 12:17 PM
As your down under it might be worth talking to Matt Read at ReadSpeed in Brisbane who has done a number of conversions, and gets his on bits manufactured.
https://www.facebook...2494518057/home
Hi,
#299
Posted 07 August 2016 - 05:51 PM
Finally the wheel cylinders arrived from minispares, I replaced the faulty one today. Next up was bleeding the brakes, on the last caliper I, thought I would just nip up the nipple a 1/4 turn more and it sheered off. The minisport calipers use an M10 insert which the nipple screws into. I wonder if I can just use an M10 nipple?
Spent a good few hours mounting the exhaust. Ended up having to take an inch of the Y piece as the system was too long. I had to do it on the car, as i couldn't get the Y piece of. Not my favorite lying upside down with an angle grinder. Though the exhaust is now on.
I have never been happy with how low the CAT hangs. it just seems like the system needs another mount /support there. I wonder if anyone has added an extra mount.
#300
Posted 07 August 2016 - 06:17 PM
Still waiting for my bonnet from arc angels.
Ordered it on the 22nd of July and was told it would take 2 weeks. I asked if I could pay extra to have the order expodited. We agreed on a sum and they said they would do it over the coming weekend.
Was told that the courier would pick it up on the 28th (I paid about 70 quid for the courier).
Nothing has arrived. I ask what the status was last wednesday and was told they would send me a tracking number. I never received it.
Dont mean to rant, just frustrated.
However! AndyR was kind enough to send me the bonnet he modified (pics on previous page) It might arrive tomorrow.
