Bmw 16V K1100 1380 Engine
847 replies to this topic
#16 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 February 2016 - 09:03 PM
I like it!  What pistons are you leaning towards Craig?
The piston choice has my head spinning a little.
Options
- MED - Omega die cast 73.5mm with a 7cc dish (330 pounds) - those have an offset dish, I not sure is this works with the 16v head?`
- minispares 3.5mm POWERMAX PISTON 9cc dish (300 ish pounds)
- minisport Powermax Pistons - 73.5mm - 7cc dish (263 pounds)
- KalverST does a set of 73mm (1360) with a 10cc dish and and set of +60 with 6.5cc dish, I have enquired to see whether he can get the 73mm pistons with a 6.5cc dish.
As always open to suggestions.
So I have gone for the Omega pistons 7cc dish (73.5mm)
have also agreed with SC to build the short block. Nothing fancy:
Standard rods with resized big ends
ARP conrod bolts
Regrind and balance of a standard crank
Jackshaft
And the omega pistons
#17 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 04 March 2016 - 12:46 PM
Gearbox ordered from Guessworks:
Helical box
cross pin diff
3.44 final drive (3.2 wasn't an option since that is what is currently have and i needed a different FD to help with the registration of  the car being modified)
I think in the end it was a good choice of final drive. It is what Specialist components recommend for my engine. I don't do long journeys on the motorway.
And of course there are speed limits but not limits on how fast you accelerate to that limit.  :shy:
I decided an against straight cut drops; I wanted to be able to hear the engine. But also a mini has enough bangs, creaks, squeaks and rattles without adding a whine.
#18 Richie83
Richie83
  • 1,495 posts
Posted 04 March 2016 - 04:24 PM
I've got the exact same setup. It's even fine on the motorway to be fair.
#19 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 04 March 2016 - 07:28 PM
Good to hear! I was worried that the 3.44 was too much of a compromise!
#20 Richie83
Richie83
  • 1,495 posts
Posted 04 March 2016 - 08:36 PM
I'm not saying it's ideal but you won't be revving the nuts off it at cruising speed. It will be very noisy though :-)
#21 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 21 March 2016 - 04:30 PM
Email from SC today:
Screen%20Shot%202016-03-21%20at%2017.26.
not long now!
#22 Black.Ghost
Black.Ghost
    Formerly known as TneMini.
  • 2,567 posts
Posted 25 March 2016 - 08:58 PM
Loving this. I really like this Mini and it'll be good to follow the progress on this. Videos once installed and running are a must.
Good luck with it all.
#23 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 March 2016 - 11:07 PM
I have tentative plans to remove the old block this weekend. and clean up the engine bay.
I did a compression test of the SPi block 198 psi across each cylinder, should help when I come to sell it on!
#24 Alex_B
Alex_B
  • 4,573 posts
Posted 25 March 2016 - 11:09 PM
If you can get a leak down test done as well, that gives a better idea of engine health and could well help sell it!
Will be following this thread as I am getting together a 16v twin kam turbo at the moment, currently saving up to get the kit.
#25 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 March 2016 - 07:18 PM
Made a start today,
Cleaned out the garage, car in the air.
52BCA8ED-7E5B-46A7-8A64-56CBDD5C412F_zps
Fuel tank removed. I will reuse this spi tank but with a mpi pump.
C3B71DA6-1C9E-4250-9FE1-2089E6CE0082_zps
Removed the sump guard, bonnet and towbar. I intended to sell the tow bar but i now 8 holes in the boot floor, I cannot weld and don't have welder. maybe i just refit the tow bar.
Lets call this a gentle start.
#26 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 March 2016 - 08:07 PM
Got stuck in again tonight! the radiator bottom hose caused me a bit of hassle. the jubilee clip spun away from me, so i couldn't get a socket on it.
Fairly enjoying myself though. just the Spi wiring loom to remove and then it is time to get the engine out.
One thing I wonder about is where will I take a vacuum for the brake servo on my new engine?
#27 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 30 March 2016 - 12:42 AM
I think you'd have to tap into each of the inlet runner's between the throttle butterfly and the head join them all together to the brake booster. If you take 1 or 2 those cylinders could run lean stall etc this is assuming you are using ITBs.
#28 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 31 March 2016 - 11:51 AM
I guess it will be possible to use the standard vacuum line from the bike for the brake servo.
Screen%20Shot%202016-03-31%20at%2013.44.
#29 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 02 April 2016 - 06:01 PM
Probably not a big deal for the seasoned tinkerers and mechanics here; but today I am extremely pleased with myself. '
12919079_10155361013381959_1405394619_n_
#30 FlyingScot
FlyingScot
  • 2,664 posts
Posted 02 April 2016 - 06:44 PM
Ya posing bass :lol:
