Bmw 16V K1100 1380 Engine
847 replies to this topic
#241 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 17 July 2016 - 08:39 AM
Dah dah! Engine meets car, fantastic!
#242 Richie83
Richie83
  • 1,495 posts
Looking good. Will work a treat with a little bracing removed.
#243 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 17 July 2016 - 07:35 PM
Yeah I think it should be fine.
#244 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 17 July 2016 - 07:38 PM
All engine mount bolts in and torqued up.
Is definitely not the easiest job. The special tool of the day helped though.
89BF7491-4252-4F49-B07D-7B0C97C1C302_zps
Spanner and gaffer, used this to insert the bolts from the engine side. Managed the rear right hand side with the radiator in place.
Looking at the cooling system I have a bypass on the thermostat and a smaller diameter hose coming from the bottom hose. I assume these could be plumbed together? But if I wanted t connect the heater what would I need ? a T piece or just plumbed in directly?
#245 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 July 2016 - 08:31 PM
Manifold on tonight, real has pushed the engine forward, the manifold basically touches the bulkhead at the moment. I will be able to push it away a bit with the adjustable engine steady, but as expected it is tight. Seems like it was good idea to wrap the manifold.
C1FAB7AE-F955-4A71-BF1B-CFA0BDF003EC_zps
In the centre of this picture you see two oil drain lines, the manifold is about 15mm away from these. I have no experience of how hot a wrapped manifold gets, so I wonder if these will be ok?
5D472D3B-5F4F-4B60-A8C1-CB258C2050BD_zps
In this picture the manifold can be seen actually touching the large silicon drain pipe, I have wrapped the said pipe in exhaust wrap, opinions on whether this will be good enough welcome.
64FB4D46-BD5C-4115-BFED-EE8BDF9ACD03_zps
#246 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 July 2016 - 08:23 PM
Offered the bonnet up for real today. It doesn't fit as well as it did, this is due to having the manifold fitted (see previous post) this has pushed the engine forward.
I started by removing the bracing where it fouled. Mainly above the cam pulleys.
EAE9B4EF-CFAF-4CF3-869E-AFDE6B98D470_zps
It actually fouled the oil filler too, so i basically had ti cut the whole centre section of the bracing out. I hope I can bond the remanning bracing too the bonnet with something?!?
789BA00A-FC61-40CD-A40D-880B30E122F2_zps
Also removed the pin and its bracket it basically sat directly in front of one of the trumpets
AC88ECF3-1683-4A8D-A166-FFB6504D5632_zps
I ten fitted a set of bonnet lifters i bought from minivation. I lil etch look of a raised bonnet so not too bothered about having to use them.
But and this is a big but the bonnet still fouls on the very right of the cam cover. right where the blue cross is
0C9676DC-FAB2-498F-891B-BECE0D4A6F70_zps
954B653C-7BCF-4993-9266-8DEFBCAE22E1_zps
FD3DFE75-3BBC-4D0B-A0E0-4BD543CFE5F0_zps
Beyond fitting some sort of bulge/teardrop (anyone know any suppliers?), i am not sure how to tackle this
#247 Richie83
Richie83
  • 1,495 posts
Posted 19 July 2016 - 08:34 PM
I was told it didn't need a bulge. But alas mine has one made of steel. My bonnet has corner bracing only, but I don't use hinges (it's still very rigid).
E7CAF95A-9D3B-45C6-B5C0-10297E49CFB0_zps
#248 Carlos W
Carlos W
  • 10,115 posts
Posted 19 July 2016 - 08:37 PM
I hope you're not fitting minivation hinges with the hydraulic support to that bonnet mate.
That's a lot of modification
#249 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 July 2016 - 08:44 PM
nope just the hinge brackets
#250 nicklouse
  • 19,056 posts
Posted 19 July 2016 - 08:45 PM
Craig,
Have a chat with ABS facebook messenger is good.
http://www.absmotors...et-without-lip/
Might not be quite the image you wanted. But you could ask about getting it in carbon and with hinge plates fitted.
But I would put a hold on worrying about the bonnet until you have the engine in final place and running.
You may need to tilt the engine forward a bit to give some exhaust clearance. And that will effect the bonnet fit.
#251 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 July 2016 - 08:56 PM
Cheers Nick, I knew about these 16v bonnets. They are a bit cumbersome, given that i only need a small bulge. however i keep them in mind.
Dangerous thing googling "mini bulge"
#252 Pickup76
Pickup76
    Ring Runner 2005
  • 1,191 posts
Posted 19 July 2016 - 09:25 PM
Looks like yours fouls exactly the same as mine did. Having seen some of the SC cars that seem to fit ok I was worried something wasn't straight on mine. Even with the auto frame I'll have to cut the bonnet strengtheners so I'm interested to see what you do and if its rigid enough.
#253 nicklouse
  • 19,056 posts
Posted 19 July 2016 - 09:38 PM
Your other option is panel beating. Spend some time asking about locally. There will be someone in a barn in the back of nowhere that can do it.
We had a tame welder called Jesus who had a barn two times the size of his house.
He also had a old Volvo with a massive turbo on it.
#254 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 July 2016 - 09:43 PM
More I think about it the 16V bonnet from abs or arc angels seems like  anise option. it is for the KAD engine so I wonder if it clears the SC bike head?
#255 nicklouse
  • 19,056 posts
Posted 19 July 2016 - 09:55 PM
From a look. See the lipless one for pics it should be easy. But again ask. Abs Motorsport on Facebook, tony get back to messages fast.
Will make to order in fiberglass or carbon and if you want hinges and fixings they can be done.
And then there is carbon weezel. Made to order long waiting time. But excellent. And I know he has a few bonnets on BMW bike headed minis.
Again fast to respond but you better sell a kidney.
Edited by nicklouse, 19 July 2016 - 10:00 PM.
