Bmw 16V K1100 1380 Engine
847 replies to this topic
#226 nicklouse
  • 18,562 posts
Posted 15 July 2016 - 02:07 PM
4 sock filters.
two pairs of socks for your birthday. not too bad.
#227 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 15 July 2016 - 07:23 PM
4 sock filters.
hahaha - I wish i even got that
#228 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 15 July 2016 - 07:27 PM
Spotted a potential very expensive mistake tonight.
I saw that the cam belt would have rubbed on one of the 'fins' on the water pump. I had removed one per the SC instructions but noticed tonight another needed grinding of.
32FA644B-6AE2-44D5-A245-FBCFEFD79A32_zps
Still tight (like everything else)
F3AE5C04-AAFC-4DE7-AA58-5C0E8B0E3FC4_zps
Also realized that i would not be able to fit a new fan belt in the future without removing some more metal from the engine mount/ radiator bracket. The trigger wheel would have got in the way .
#229 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 15 July 2016 - 08:35 PM
"Custom" really  means custom. doesn't it? :proud:
#230 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 15 July 2016 - 08:54 PM
[quote name="minisilverbullet" post="3403545" timestamp="1468610841"]
I like the thread marks on the pump housing. Been there.;-)
Edited by HUBBA.HUBBA, 15 July 2016 - 08:57 PM.
#231 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 15 July 2016 - 09:46 PM
I like the thread marks on the pump housing. Been there. ;-)
Yip, it is my favorite feature! :shy: I did wonder for a second why the fan wouldn't turn.
#232 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 15 July 2016 - 09:47 PM
lets just say it has been a steep learning curve
#233 FlyingScot
FlyingScot
  • 2,664 posts
Posted 15 July 2016 - 10:40 PM
Thanks for doing it for us Craig :thumbsup:
FS
#234 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 16 July 2016 - 11:58 AM
I have the same trigger wheel as you for my SC 7 port conversion and therefore had the same fan belt clearance issues. I did send you some pictures on post 145 of your build showing the clearance after fitting but given the large amount you have to do you may have missed them. The main problem I came across was when I removed enough of the mounting bracket to clear the fan belt the bracket was weakened just enough to make it flex in the vice. I was worried about the long term integrity of this due to the increased torque going through and whilst it may be over engineering it I welded a couple of fillets on the back of it to add back the strength. I used the genuine rubber engine mounts so it does make fitting the nuts to these a little difficult but I prefer these mounts to the ones with captive nuts. I still have to take off the sensor to change the belt but its better then taking off the bracket at the side of the road.
Edited by Northernpower, 16 July 2016 - 11:59 AM.
#235 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 16 July 2016 - 06:17 PM
Yes I remember, but  I overlooked the bracket description as I was too focused upon the damper pulley.
I haven't actually removed so much metal from the part of the bracket which takes the weight of the engine, more the top part where the radiator bracket sits.
#236 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 16 July 2016 - 06:44 PM
Well the journey between my two garages with the engine began:
6AFB4967-5011-4012-9784-D5D8D436889C_zps
Even managed to get my girlfriend involved.
639FF44E-338E-4225-BA0C-35D4FE5546FC_zps
234242EC-8458-4AB0-88F9-F6F82DD5ADE7_zps
Dogs were as happy as I was.
574B2E9D-C3A8-492A-B0DE-0D0FC9E81031_zps
Ta Da:
48180840-DCE6-47C2-82A1-E481A27EE90C_zps
19B00682-9CBB-4189-A8D9-29E525CE8AAA_zps
Even the bonnet doesn't fit anywhere as near as bad as i thought. This is teh standard bonnet still with the brace etc. I do plan to lift the rear so , it should be fine with a bit of the bracing removed.
0DEF08D2-EC95-4155-8BA6-84104273920C_zps
#237 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 16 July 2016 - 07:04 PM
Looking very good in the car.
#238 mad mk1
mad mk1
  • 746 posts
  • Local Club: TurboMinis.co.uk
Posted 16 July 2016 - 08:09 PM
Looking spot on mate! Keep it going!
#239 Rocket.
Rocket.
  • 1,441 posts
Posted 16 July 2016 - 08:26 PM
Great build !
Looks awesome in the car
#240 FlyingScot
FlyingScot
  • 2,664 posts
Posted 16 July 2016 - 08:32 PM
That looks magic Craig. Very impressive.
FS
