Bmw 16V K1100 1380 Engine
847 replies to this topic
#166 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 29 June 2016 - 05:56 PM
I use 11/32 for 1/8npt.  An 8.7 should be fine, the 8.5 might be a bit tight meaning you wont get full engagement of the thread or need excessive force during cutting to get the full taper.  But in a pinch i am sure you can get it to work!
Andy
#167 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 29 June 2016 - 06:00 PM
That would just be a 90deg an fitting.  I like the superflow swivel fittings from torques as they have a slightly bigger bore on the bends and the swivel fitting makes it much nicer to get the angle of the hose you are after.
Andy
#168 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 June 2016 - 08:10 PM
Andy
Thanks Andy I checked and I couldnt find any an-3 swivel fittings, I guess I will work with what i bought.
#169 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 June 2016 - 08:22 PM
While the goes and fittings arrive.
I looked at the alternator fitting tonight.
This nice little adjuster arrived today, put together by a small company selling on ebay, customer service great. I love these small firms.
4a33cb01-0e06-4c03-ad78-eba55f5224fd_zps
Looks alright fitted. It fouls the bottom of the alternator a bit, so i will fill of a little material from the alternator.
610DEBB3-6423-4787-9911-446B0F620163_zps
Speaking of the alternator, is there any thing wrong with mounting it like this at the top ear? I.e just bolted to the water pump hole?
4C58C1CB-E4E6-4FD1-8DC5-15485088E81F_zps
E6AF4A5A-5651-424C-A407-844790777A55_zps
Then there is the the belt fitment. as you see the alternator pulley isn't directly in line with the water pump pulley. Is this acceptable? I guess i could file the mounting face of the alternator.
661C30CD-C5A7-4733-8D3C-32715E5FB119_zps
The water pump and the crank pulley are inline with each other.
#170 mini13
mini13
  • 3,810 posts
Posted 29 June 2016 - 08:58 PM
I had my alt attached on the waterbuck only and it snapped the lug off the water pump, I added the std bracket ton the block and a long bolt and spacer to go between both
#171 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 June 2016 - 09:15 PM
oh! thats not good. do you happen to remember where you found such a long spacer?
#172 Streetscreamer
Streetscreamer
  • 16 posts
  • Local Club: Mini Seven Club Netherlands
Posted 29 June 2016 - 09:22 PM
... what if you turn the alternator upside down? The mounting eyes are on different positioned ears. Might give you a better situ for your belt alignment.
#173 Streetscreamer
Streetscreamer
  • 16 posts
Posted 29 June 2016 - 09:24 PM
Sensor: often a gap of 1 - 1,5mm will do. But be sure the center of the sensor will be in center of the trigger wheel in order to have the best functioning.
Yes I think I will ask SC to send one more spacer to bring the magnet into the centre of the wheel.
You might make it yourself... where assembling ends, building starts!
#174 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 June 2016 - 09:33 PM
unfortunately won't work.
the picture makes the alignment look worse than it is in reality it is about 4mm out.
#175 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 June 2016 - 09:34 PM
Quickly learning that.
In the end I just added 1 appropriately sized washer. Bracket is secure, no wobbles.
#176 nicklouse
  • 18,562 posts
Posted 29 June 2016 - 09:53 PM
Make it Zero.
#177 mini13
mini13
  • 3,810 posts
Posted 29 June 2016 - 10:12 PM
I just cut a piece of all tube that I ha to suit, will get a pic tomorrow.
#178 mad mk1
mad mk1
  • 746 posts
  • Local Club: TurboMinis.co.uk
Posted 29 June 2016 - 10:55 PM
It's best to file the body to bring it in line mate.
#179 mini13
mini13
  • 3,810 posts
Posted 30 June 2016 - 10:29 AM
yes, if you cut back to that casting mark that is pretty much right.
#180 Squares
Squares
  • 34 posts
Posted 30 June 2016 - 10:59 AM
Hello, I just read all 12 pages of this awesome project.
Well done and thanks for sharing. Looking forward to the updates.
