Bmw 16V K1100 1380 Engine
847 replies to this topic
#136 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 June 2016 - 06:35 PM
Well a couple of steps backwards this evening….
I thought I would set top dead centre on piston one and set the trigger wheel up and maybe time the cams.
I started to turn the crank by hand and something was binding. I could not really figure it out.
The only thing I could think it could be were the valves, so I started to remove the head to inspect. To remove th head you need to remove the camshafts first. As I half way through, I thought I would rotate the engine again and it sounded like it was binding at the flywheel.
A bit of head scratching, and I decided to remove the engine mount on the clutch housing side. That was the issue the bolts I had used where too long.
Checking again on minispares seems there were the correct length?
Screen%20Shot%202016-06-24%20at%2020.30.
So I started to refit the camshafts.in doing so however, the two round springs which sit in the oil seals in the cam cover must have popped out of place. Resulting in one being chewed up when i torqued the cam bolts.
So I will need to sources two new springs. Anyone know what they are called? EDIT: springs are called garter springs, I will buy a new seal instead.
769A0490-C2D1-4DF5-909B-BA366B4905A7_zps
#137 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 June 2016 - 10:49 AM
Reflecting upon the 'dry decking'
I wonder where does the oil feed come from?
is it from the large diameter hose on the side cam cover?
#138 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 June 2016 - 07:21 PM
 little progress today.
Got the trigger wheel set up at TDC.
#139 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 June 2016 - 07:39 PM
Currently one of the mounting holes on the alternator is 10mm ideally it would be 8mm, is there such a thing as an insert /bush I can buy.
My old alternator had a split steel insert to reduce the hole size,
Any tips on what such a thing would be called or where ti buy would be appreciated
#140 nicklouse
  • 18,562 posts
Posted 25 June 2016 - 07:44 PM
Make one.
Consider the use of the insert. It is to slide in the alternator to take up slack in the system.
The belt end is mounted fixed and the other provides a pivot and the sleeve slides to take up any missmatching.
#141 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 June 2016 - 06:36 PM
Not sure how I would make one,
#142 nicklouse
  • 18,562 posts
Posted 26 June 2016 - 06:54 PM
All you need is a bit of tube and drill it out to take the bolt size you are going to use.
Just needs to be a tightish fit in the alternator.
Does not need the split.
#143 zebigfatman
zebigfatman
  • Just Joined
  • 159 posts
  • Local Club: Snowdon minis
Posted 27 June 2016 - 09:55 AM
This looks awesome! should be excellent when your finished.
This conversion was something I considered but the cost of the engine put me off and the appeal of 5 gears sold the micra engine for me. Anyway good luck with the build and also I love the silver! I'm guessing its not a standard colour?
#144 phil hill
phil hill
  • 616 posts
Posted 27 June 2016 - 01:44 PM
The oil feed can still come through the block if either the oil-way in the block or head are relocated slightly. There should be some instruction in the build book for that.
If you are going for a truly dry deck then there is an oil plug on the back of the cylinder head near the pulley end with a small grub screw in it. This is usually drilled and threaded out a bit bigger and fed via a hose from the oil pressure switch, a bit like a turbo oil feed. Again this should all be in the build book.
Phil.
#145 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 27 June 2016 - 07:18 PM
Some final bits arrived today:
4.2 inch MED water pump pulley
nippon denso alternator
Engine mount "plate" all the way from Barcelona (wasn't the easiest to find)
a 90 degree hose and connectors.
3111B792-343E-428E-B752-01EF1BC60E2F_zps
Well the 4.2 inch  pulley clears the oil hose perfectly.
C892F70A-A0D8-491E-ACFE-ADC9D4377852_zps
It is amazing how small the denso alternator is!
86268F65-ACB3-46F4-BB48-EAA8641D23C9_zps
Seems like the 90 degree hose i tried to use before was pretty poorly made, I.E it wasn't actually 90 degrees. the new ones seems to fit much better. I will order one more and use a joiner and it will clear the crank breather just fine.
3D963155-4291-4547-B874-D12CD7635AB9_zps
Seems like the fan will not clear the oil hose. This hose had been a bit of a pain (see water pulley issue above). It was supplied as an add on to the kit. I think i will need to shorten the "legs" both sides of the cam belt.
Next up is the clearance between the crank damper/trigger wheel and the radiator/engine mount bracket.
C34CC816-0A21-4002-9ED1-C33B3017DC2B_zps
It clears but it is extremely tight.
55C70ACF-654D-4CC3-B998-CEC9721D1B49_zps
53F1A51E-9FBE-4709-B827-4BE9CAECC7CD_zps
I hope it is enough just to grind the bracket a little?
Looking at your bottom bracket you have the same problem as me. I decided to reinforce mine and then remove some of the original metal. My idea is to enable me to be able to change the fan belt without removing the bottom bracket; all i have to do is remove the sensor bracket with the sensor still attached. By cutting away the metal and sliding back the rad mount I can just get the fan belt past it.
#146 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 June 2016 - 09:48 PM
Phil.
I have a feeling I may have problem.
The deck is truly dry. The only holes in the block are for the studs.
I can see the grub screw you speak of and it is still in place.
#147 nicklouse
  • 18,562 posts
Posted 27 June 2016 - 09:49 PM
You know what to do.
#148 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 June 2016 - 09:52 PM
F90C422D-74DA-450F-8C2A-A87C9453AE1E_zps
As you see only the 8 stud holes. even if the hole to the far right corner looks like a hole it is infact blocked
#149 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 June 2016 - 09:53 PM
 You mean phone SC right! I never asked for the kit to be dry decked.
#150 nicklouse
  • 18,562 posts
Posted 27 June 2016 - 09:55 PM
I though that was standard as nothing aligns.
But they should point out how the oil feed works.
