Bmw 16V K1100 1380 Engine
847 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 22 February 2016 - 07:03 PM
After years of toing and froing looking for the perfect solution which fitted my needs of more power, ease of conversion, fit within Swedish regulations and budget.
As some of you may have noticed I have posed numerous questions regarding a 7 port head with rule injection, the more knowledgeable of you pointed out the issues I would have with emissions by using a cam which suited the engine. Therefore I would needed to have made a compromise with my choice of cam,
I also looked at various engine swaps, Suzuki, Micra and Honda. These appear superb, but I felt a little beyond my mechanical competences. Also I wasn't prepared to have the car off the road for too long.
Next up I considered the bike conversions, i almost bit the bullet and went for the AElynx kit. These conversions appeared a lithe too brutal for how I want the car to be.
So…..finally today I bought the specialist components bundle kit. (taking advantage of the Kroner/Pound exchange rate today)
  • SC ‘K’ Conversion Kit
  • SC Bespoke Bi-metallic Head Gasket
  • Refurbishing, Machining and Assembly of your ‘K’ Cylinder Head
  • SC Storm 2 Engine Management System pre-mapped for your engine
  • SC Bespoke ‘K’ Wiring Loom, Ignition Coil Pack, HT leads, Coil Bracket and sensors
  • SC Ancillaries Kit (including Throttle Cable and Dipstick)
  • SC Crank Trigger Kit with Crank Position Sensor
  • Preparation of your A-series block for the ‘K’ head
  • De-grease, surface, re-bore, hone and centre main strap machining of your block
  • Pocketing of your pistons for valve cut-outs
  • ‘K’ Exhaust Manifold
  • Billet Remote Thermostat
Even though I am now suffering from a sense of post purchase anxiety, I will try and outline the specs of the engine as best i can. All comments welcome.
1380 block prepared by SC and built by Guessworks
MED Verto Ultra-Light ST1 Clutch Kit with lightened flywheel
- Pistons TBD
- Crank - balanced  x-drilled
- Conrods - Standard balanced and lightened TBC
- Steel mainstrap
- I will use the SC ECU and maintain a narrow band Lambda (for emissions)
Gearbox
- From Guessworks TBD. I think a SCCR box.
- 3.4 Final Drive.
Cylinder Head
- Cam wise - I meant to ask SC which cams cam with the kit LT or RS. Depending on emissions I would like the RS cams. I need to confirm this
- I have asked SC to machine and add a standard mini oil cap into the head
Colour (the most important part)
 - Block painted black and head painted dark grey.
#2 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 22 February 2016 - 07:07 PM
oh yes it will be going into this -
5D9BC14B-DDD0-4DFF-A524-FDEFE23083D3_zps
Intention is to keep the standard bonnet and pray that I only need to trim the cross member. If that fails, I think I might go for a nice retro rear bonnet lift.
I am also thinking of trying to have some nice chrome K&N filters somehow visible at the front.
#3 smudger068
smudger068
  • 344 posts
Posted 22 February 2016 - 08:45 PM
Awesome
Good luck with the build interested to see how this turns out
Lee
#4 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 23 February 2016 - 05:34 AM
I like it!  What pistons are you leaning towards Craig?
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 February 2016 - 09:26 AM
The piston choice has my head spinning a little.
Options
- MED - Omega die cast 73.5mm with a 7cc dish (330 pounds) - those have an offset dish, I not sure is this works with the 16v head?`
- minispares 3.5mm POWERMAX PISTON 9cc dish (300 ish pounds)
- minisport Powermax Pistons - 73.5mm - 7cc dish (263 pounds)
- KalverST does a set of 73mm (1360) with a 10cc dish and and set of +60 with 6.5cc dish, I have enquired to see whether he can get the 73mm pistons with a 6.5cc dish.
As always open to suggestions.
#6 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 February 2016 - 05:12 PM
Another option may be - calvers 72.5mm pistons  6.5cc dish (1342cc)
http://dt-vps.co.uk/...&product_id=110
#7 Anronadolfsson
Anronadolfsson
    Starting My Mini Up
  • 2 posts
Posted 23 February 2016 - 05:41 PM
- Pistons TBD
- Steel mainstrap
Gearbox
- 3.4 Final Drive.
Cylinder Head
Hi! I wonder what the limitations are according to the swedish rules? I myself are looking in to getting a mini and want to do an engine swap. All that I know about is the 200hp/ 1000kg, but are there more?
#8 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 February 2016 - 05:53 PM
- Pistons TBD
- Steel mainstrap
Gearbox
- 3.4 Final Drive.
Cylinder Head
Lots of things it seems. I really struggled with the rules etc. the age of car seems to dictate a lot of things, not least emissions and if you need to maintain a cat etc. You will need to upgrade brakes. lots of stuff on SFRO.se
I see you are not far from me in Eslöv
#9 Anronadolfsson
Anronadolfsson
    Starting My Mini Up
  • 2 posts
Posted 23 February 2016 - 05:57 PM
MED Verto Ultra-Light ST1 Clutch Kit with lightened flywheel- Pistons TBD- Crank - balanced  x-drilled
- Steel mainstrap
 Gearbox
- 3.4 Final Drive.
 Cylinder Head
Yeah thats right about all the rules. Maybe want to meet someday not so long from now? As i said, o dont have a car yet but You maybe can give some important tips when buying.
#10 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 February 2016 - 06:10 PM
 Sure! I guess you also know about hundkoja.com?
#11 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 February 2016 - 08:38 PM
So I am trying to collect all the extra things I need. I am thinking about the fueling at the moment.
I can't really make my mind up on what is the best option. I currently have an Spi tank and pump
1. Keep my Spi tank and upgrade to a mpi pump
2. Keep my Spi tank and upgrade to a walbro in tank pump
2. Upgrade to a mpi tank (due to its baffles or being foam filled, helping with fuel starvation) and an mpi pump
4. upgraded pump and then a swirl pot
Best option?
#12 Richie83
Richie83
  • 1,495 posts
Posted 24 February 2016 - 09:17 PM
Mate. It'll blow you away. I've got a SC K1100 in my pickup and its out of this world. Looking forward to this build.
#13 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 February 2016 - 09:20 PM
I hope so!
do you have a build thread?
#14 Richie83
Richie83
  • 1,495 posts
Posted 25 February 2016 - 07:03 AM
I hope so!
yes. It's here: http://www.theminifo...pickup-twincam/ 😀
#15 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 February 2016 - 08:58 PM
I hope so!
read it start to finish - good stuff
