Paint Reaction - Elephant Skin
9 replies to this topic
#1 Tregs
Tregs
  • 41 posts
Posted 21 February 2016 - 05:05 PM
Hi guys,
Wondering if anyone may be able to help identify the cause of a paint reaction that looks a bit like elephant skin.
I am currently painting the underside of my mini roof in 2k paint, it is primed using 2k, flatted and then decreased prior to this top coat. I'm so annoyed as i tried to do everything by the book and now the entire roof looks a mess, thankfully its only the underside but i want to rectify this issue before attempting to spay the top of the roof.
Anyone have any ideas?
I have an oil/ water trap plumbed into my system as well as a coalescer filter for my air fed mask.
C1D7D10C-0B9B-4DCA-BAF3-E89D7C3B736B_zps
And again with the flash, it looks as if the primer is showing through here but it is just the reflection from the flash.
480B36E1-4B11-41C1-A661-DB7C36A288FD_zps
Cheers,
Tregs
#2 Richie83
Richie83
  • 1,495 posts
Posted 21 February 2016 - 05:28 PM
How long did you leave the primer to dry before applying the top coat? Looks like thinners have crazed the paint or the temperature was not ideal? I'm sure others will be along shortly to point out what is precisely wrong, I'm just theorising from what I've seen in the past.
Edited by Richie83, 21 February 2016 - 05:30 PM.
#3 clubman91
clubman91
  • Just Joined
  • 137 posts
Posted 21 February 2016 - 05:32 PM
Your not using an oiler when spraying are you?
#4 Tregs
Tregs
  • 41 posts
Posted 21 February 2016 - 05:37 PM
i left the primer to harden for approx 4 hours, could this be the issue do you think? How long should it be left in between coats?
No i am not using an oiler.
#5 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 21 February 2016 - 05:49 PM
Mine looked a bit like this when I primed mine.
I used celly though.
My problem was using too much thinner.
Don't know if that'll be the same case with 2K.
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 21 February 2016 - 06:09 PM
looks like paint reaction whats under it all?
#7 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 21 February 2016 - 06:38 PM
2k Primmer not cured properly! heavily applied in some areas , to achieve a good finish primmer
needs as much care as top coats (read Data sheet for curing times
#8 Tregs
Tregs
  • 41 posts
Posted 22 February 2016 - 07:35 AM
Thanks, I think I should have left it to cure for longer. I'll give it another go
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 22 February 2016 - 08:24 AM
Remember, if the weather is cold it will take longer to cure
#10 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 23 February 2016 - 11:30 PM
Overnight at least, even in a heated garage
