Engine Bay Paint?
Posted 20 February 2016 - 08:35 PM
I was thinking of using por 15 topcoat,or even there chassis paint(both brush applied),but do I need all of por 15 degreaser/thinner etc,? As this just makes it more expense.
Posted 21 February 2016 - 09:24 AM
Did this on mine early last year and its been fine since.
Posted 21 February 2016 - 11:36 AM
Posted 31 July 2018 - 07:46 AM
engine bay resprayed
Posted 31 July 2018 - 08:01 AM
Hi,
I'd de-grease, prep and flat. Then go to your local car paint place and get them to mix you up a couple of large black aerosols, not off the shelf stuff.
Spray them on, job done
Edited by Bat, 31 July 2018 - 08:02 AM.
Posted 01 August 2018 - 11:14 AM
Rattle cans would probably be your best bet. A few decent primer layers with etch or zinc, a build up primer layer and then a couple of your choice colour coats and some clear coat.
Surface prep for each layer is the really key thing.
Posted 18 September 2018 - 08:52 PM
if you are having the rest of the car resprayed, havent you thought of getting the bay done at the same time? it will look so much better than brush-applied paint, and wont cost a fortune to do a mini bay.
