I don't normally ask for help, but this time I'm really stumped and begging for your ideas. I've searched the forums, and found some pretty similar topics, which have given me inspiration, but still haven't managed to fix it...
I'm running an SPI with CAT temporarily removed and a carbon monoxide meter to do some tests. With the engine warmed up, she'll hold steady at somewhere betwwen 1.7% to 2.5% CO (sometimes lower). After 60-75 seconds it'll shoot up to 6.5%. It seems to be going into some kind of fail-safe mode, but as you can imagine this has killed the original CAT and failed on this years MOT.
I've replaced the lambda, and water temp sensors. The stepper motor clicks as normal ( and can be reset with the accelorator pedal trick ). The throttle pot reads between 0V and 5V using a multimeter.
??? Any suggestions what to do next ???
