Hi all,
I'm just posting this because I had a look around when I was looking at putting in a steering u-joint, and didn't find any easy options discussed. When putting my Mini Marcos together, the thickness of the body shell combined with some other factors, I ended up with the hole for the steering rack spline aiming a bit too high for the steering column to fit past the lower edge of the dash. I could have done some more digging out of the fiberglass, but decided I wanted a u-joint anyways, so started looking at options. I hope this post helps someone else, it would have saved me a bit of time in the process. A u-joint in the steering column can be nice to allow a lowering bracket without loosening the steering rack.
The bottom of the steering column is cast, and not round, and is hollow, making it not very easy or safe to cut off the bottom inch and weld on a u-joint. All of the u-joints I've found, at least here in the states, had female splines, meaning they could mate with the steering rack, but not the bottom of the steering column. I looked at getting some 9/16-36 splined shaft, to turn a double-female u-joint into a female/male one, however nobody here has any that I could find.
I ended up finding that the cast portion at the bottom of the steering column is actually a female female splined coupler, welded onto the column. A bit of quick grinding, and that came off, and I now have room to fit on a u-joint like this:
http://www.summitrac...arts/brg-111212
I will still need to drill a slot so that the set screw can lock the joint onto the shaft, but that's a lot easier than most of the other options I considered.
Here's the picture of the column, with the bottom coupler cut off. If I were to do it again, I would leave about 1/2" of the coupler still attached to the column, and have done a circular cut to split it.
