Starter Motor Clicking But Battery Charged?
Posted 30 January 2016 - 03:10 PM
Posted 30 January 2016 - 03:20 PM
Posted 30 January 2016 - 03:28 PM
Posted 30 January 2016 - 03:34 PM
Posted 30 January 2016 - 03:41 PM
Try connecting another car with jump leads, in that way you can be sure you have enough power to start the Mini.
When it is still clicking there is a big change the problem will be the starter motor or an earth problem and not the battery.
Posted 30 January 2016 - 04:41 PM
Posted 30 January 2016 - 04:47 PM
Possibly jammed starter motor might just need a clean
Posted 30 January 2016 - 05:07 PM
Posted 30 January 2016 - 07:34 PM
That could well be right. When reattaching the battery I put negative on first
Just a side point: - I always understood it is best to connect the positive cable first, then if you accidentally touch the body when swinging the spanner no problem, but if you connect the negative first, i.e. the earth cable, and you accidentally touch the body when swinging the spanner connecting the positive cable then you short out the battery.
On the original point - are you sure it is not the starter solenoid clicking. This thing http://bullmotifmini...f000010_bmk1728
Edited by greenwheels, 30 January 2016 - 07:37 PM.
Posted 30 January 2016 - 07:45 PM
Your battery sounds like it has a dead cell in it and is not holding charge. Try to start the car using jumper cables from a car that's running. If your mini fires up straight away, it's the battery.
Posted 31 January 2016 - 01:50 PM
Charged up the battery and put it back in this morning and it got going okay? The test will be to see if it holds the charge. Fingers crossed. Thanks
Posted 31 January 2016 - 09:24 PM
Voltages showed 12v+
He took the battery back under warranty and although it showed OK, they replaced it. No change.
Checked the car for a drain on the battery. Nothing of any significance showing.
Hooked a jump lead up to another car. No change.
Went on Internet and found it may be the earth lead (as previously mentioned).
Cleaned earthing point in boot and lead. No change.
Purchased a new braided earth lead and fitted it between the engine and the body using the already present earth near the servo.
Car started first time.
Although the starter relay did pack up shortly afterwards so was replaced as well.
Car has been fine since and starts easily.....
