Noted :)Don't put mains pressure water through the heater matrix! It will burst it especially if it's getting on a bit.
#16
Posted 24 January 2016 - 07:51 PM
#17
Posted 24 January 2016 - 08:02 PM
#18
Posted 24 January 2016 - 09:07 PM
Edited by KernowCooper, 24 January 2016 - 09:13 PM.
#19
Posted 24 January 2016 - 10:01 PM
How would I go about reverse flushing the system and doing a coolant sniff test? sorry bit of a newbie as stated earlier. I will order a compression test kit and carry out the test later this week, although I think I will get a new water pump anyway and flush the heater matrix as it probably needs doing - preventive maintenance. Thanks for all the advice so far!
Kind Regards
George
Edited by WimpyMiniMan, 24 January 2016 - 10:01 PM.
#20
Posted 27 January 2016 - 03:51 PM
UPDATE: I decided it was unlikely to be the water pump as that was replaced in 2014 by the previous owner, and when the thermostat opened, the radiator was drained of fluid. I bought a compression kit and carried out the test and got the following:
C1 C2 C3 C4
Dry 160 135 120 130
Wet 190 135 130 155
I then, suspecting a leak in cylinder two, ran the engine with the rad cap off, and sure enough, once the thermostat opened, white smoke started to pour out of the radiator filling hole. I suspect the engine head will need to be taken to an engineering firm to see if they can fix the leak, and possibly convert to unleaded (not sure if my 1989 city e 1000 is unleaded). It will also need to be skimmed and I will need to get new o rings.
Does any one have any other suggestions?
Kind Regards
George
#21
Posted 27 January 2016 - 06:20 PM
The head itself will unlikely be cracked causing the leak, just the gasket between the head and the engine block may have failed.
None the less, it would be wise to have the head overhauled while it's off.
If I may suggest, while you do have some enthusiasm for spinning spanners, while changing a head gasket is not a difficult job, given your limited experience, can I respectfully suggest that you find someone who can work with you - hands on - to do this or consider paying to have it done?
While it is fairly straight forward, it can also turn in to a bar-stool of a task that can end in some real disappointment and a long face too. Having someone help you will build your like for the car and give you a broader understanding.
#22
Posted 27 January 2016 - 06:51 PM
Will I need to have the engine block skimmed as well as the head, and also how much do you would reckon it would cost to have the head refurbed? If it is cracked what sort of money could it cost to have that rectified? I have seen an entire engine on gumtree for £250 thats just come out after a vtec conversion job. The owner has assured me the engine is in good condition and has done around 84,000 miles and would mean I could use my car whilst repairing the other engine. It looks fine usual surface rust and I could potentially refit my current engine afterwards or even sell it. Being a 1989 city e I don't imagine original parts will influence its value much.The head itself will unlikely be cracked causing the leak, just the gasket between the head and the engine block may have failed.
#23
Posted 27 January 2016 - 07:08 PM
C1 C2 C3 C4
Dry 160 135 120 130
Wet 190 135 130 155
Kind Regards
George
Never assume parts will be good or have a long life expectancy! There are a lot of shysters out there who sell a gash part.
#24
Posted 27 January 2016 - 07:32 PM
C1 C2 C3 C4
Dry 160 135 120 130
Wet 190 135 130 155
Kind Regards
George
even though the radiator was drained when the thermostat opened do you think the pump may not work? Also I'm sure there was combustion gas in the coolant system which would explain the lack of increase of pressure during the wet test. So people reckon a new gasket and skimming of the head and block could solve the problem?
Edited by WimpyMiniMan, 27 January 2016 - 07:53 PM.
#25
Posted 27 January 2016 - 08:08 PM
#26
Posted 27 January 2016 - 08:45 PM
ordered new gasket set as that will be replaced either way - will take head off on the weekend and have a look. Do you think just a skimmed head and new gasket will solve the compression issue on all four cylinders?
Edited by WimpyMiniMan, 27 January 2016 - 08:45 PM.
#27
Posted 27 January 2016 - 09:12 PM
#28
Posted 28 January 2016 - 04:41 AM
sure thing will post an update after ki've had a look.
#29
Posted 28 January 2016 - 06:35 PM
#30
Posted 28 January 2016 - 06:57 PM
Edited by WimpyMiniMan, 28 January 2016 - 06:57 PM.
Mini Technical Sections →
Problems, Questions and Technical →
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
Tips On Buy An Used Su Hs4 CarbStarted by hfolguera , 17 Mar 2025 ![]() |
Engine Has Been Sat 10 YearsStarted by JHN_mini , 15 Mar 2025 ![]() |
