Hi Lo's Front Adjustment Lock Nuts Which Way Round
Best Answer jcab , 26 January 2016 - 09:40 AM
ok i take it the bottom nut is fixed .. lock top nut to trumpet.
got it thank you. appreciated.
There is a trumpet a bolt and a nut. The nut is an optional extra and was never provided in the original versions and should be removed if needed to get the car lower.
The bottom hex head is what you turn to adjust the height.
Yes thankyou i have adjusted the bottom nut which turns the bolt in the Trump adjusting its height .(set up high for road use) I then tightned up the top nut against the trump this has now locked into postion ..so seems fine . thanks again.
Go to the full post
8 replies to this topic
#1 jcab
jcab
  • 30 posts
Posted 24 January 2016 - 11:52 AM
Can some one please advise which way round to lock the front Hi los a picture would do nicley.
I mean the the two nuts on the hi lo.. it self ..how to lock this correctly
thank you.
#2 nicklouse
  • 18,577 posts
Posted 24 January 2016 - 12:09 PM
Only really one way to lock any nut. And in this case onto the trumpet.
#3 jcab
jcab
  • 30 posts
Posted 24 January 2016 - 12:17 PM
Ok thanks but can you be specific having m.o.t probs . I need to lock this up its slipped.
Is this one nut locked up to trumpet or both nuts ? is one fixed to bottom I cannot remember please advise.
thanks.
#4 nicklouse
  • 18,577 posts
Posted 24 January 2016 - 12:21 PM
There is only one nut per side.
Once you have set the height use it to lock the bolt off.
#5 jcab
jcab
  • 30 posts
Posted 24 January 2016 - 12:26 PM
Edited by jcab, 24 January 2016 - 12:31 PM.
#6 Spider
  • 14,840 posts
Posted 24 January 2016 - 05:52 PM
Is there a thread in the main body ('trump') section of the Hilo or is it just a plain hole?
#7 nicklouse
  • 18,577 posts
Posted 25 January 2016 - 12:49 AM
#8 jcab
jcab
  • 30 posts
Posted 26 January 2016 - 09:37 AM
Hi thanks for your assistance ..There must be a thread in the (Trump) The bottom nut is what seems to adjust the height so i set it up and tightened up
the top nut to trump this has now locked up so it should be fine now.
I was not clear of which side i should tighten up to lock this into position . but sorted now.
thanks
#9 jcab
jcab
  • 30 posts
Posted 26 January 2016 - 09:40 AM   Best Answer
