Apologies - I missed one of the measurements you wrote in your initial posting.
Now;-
In the older Haynes manual it states that the bearings with Thrust written on them must have an 11 thou preload, this is what I based my calculations on.
Cricky! Mmmm,,, I think you'd have some burnt out bearings with that much pre-loading! I've just looked in a Haynes manual I happen to have and this one does say 0.011" without the gasket - which these days, is a fairly onerous way to state it as the gaskets as supplied in are different thicknesses.
OK, the Factory info on the A+ Gearboxes / Diffs says a 0.004" Preload.
Can we just go back a few steps here just to be sure?
Place the diff in the gearbox and bias it all the way towards to the flywheel side, fit the diff cap, on with spring washers and bolts, do up the bolts BUT just until they touch the spring washers and then about 1 - 1/2 flats more, so that the cap is firm but definitely not tight.
Fit up the Flywheel side Cover with the gasket and all bolts, do the two that are in the case right up and then just nip the other 3.
This removes any free play from the bearings and applies a bias in a preload direction as well as squaring up the bearings.
Fit up the radiator Side Cover by hand as you have, no gasket, measure the gap.
Preload for the A+ is 0.004". The earlier boxes were 0.001 to 0.002" (and this is all I ever use).
So, let's say the gap is 0.016 and the gasket (crushed) is a measured 0.011", viz;-
0.016 - 0.011 = 0.005"
So at that, no shims would be needed.
However, from my experience, this doesn't seem right as they always need some shims.
Another example;-
Gap (no gasket) 0.008"
Gasket 0.011"
The 0.008 - 0.011 = - 0.003" (note this is a negative figure, which is what I'd expect)
-0.003 + 0.004 (preload) = 0.007" Shim.
Sorry for the long winded reply, but I wanted to be sure you have the right info as what you have initially found doesn't look right to me.
Edited by Moke Spider, 24 January 2016 - 08:50 AM.
