Saxo Engine Install, My Progress So Far.
58 replies to this topic
#1 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 15 January 2016 - 09:58 PM
After spending countless hours trying to stick a saxo engine into a modified mini subframe I'm needing some advice off some more experienced engine converters.
Basically just want everyone's opinion on whether I'm wasting my time and to point me in the right direction to any mistakes or problems I may encounter in the pictures below.
In other words does it look like its gonna actually work once finished.
Edited by cookie4343, 15 January 2016 - 09:59 PM.
#2 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 15 January 2016 - 10:20 PM
Dude...a saxo engine.....seriously??!!
#3 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 15 January 2016 - 10:23 PM
Anythings possible mate ! Also using different engines stand out more from the usual conversions everyone does. Just mock it all up first make sure everything fits and is in line. Looks good so far :)
#4 jackjewelljj
jackjewelljj
  • 241 posts
Posted 15 January 2016 - 10:28 PM
Better than a micra engine lol
#5 cookie4343
cookie4343
  • 2,257 posts
Posted 15 January 2016 - 10:31 PM
Good reliable motors, all ally block as well lol.
Just sticking to a engine I know.
#6 petey81
petey81
  • 1,331 posts
Posted 15 January 2016 - 10:36 PM
Vts yeah nothing else though.
#7 acrowot
acrowot
  • 278 posts
  • Local Club: manchester minis
Posted 15 January 2016 - 10:57 PM
 I have a 106 rallye  engine in my race car goes really well  there a cheap easy to mod engine gear boxes are rubbish though
#8 cookie4343
cookie4343
  • 2,257 posts
Posted 15 January 2016 - 11:12 PM
Don't happen to have any pics of your gear linkage setup do you or any pics for that matter.
I've got the two top linkages installed but the steering rack gets in the way of the bottom linkage, I think this just stabilises the selector rod so was gonna move the ball and make a bracket closer to the selector and Re weld ball, hopefully that will work.
Edited by cookie4343, 15 January 2016 - 11:15 PM.
#9 cookie4343
cookie4343
  • 2,257 posts
Posted 15 January 2016 - 11:14 PM
I've got the two top linkages installed but the steering rack gets in the way of the bottom linkage, I think this just stabilises the selector rod so was gonna move the ball and make a bracket closer to the selector and Rebels ball, hopefully that will work.
Also has the 106 rallye engine got a alloy or cast iron block.
#10 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 16 January 2016 - 10:58 AM
Bit hard to tell from the shots but are your driveshafts lined up as well as they can be?
Frame looks nice....with the frame almost done you can see the finish line.
#11 cookie4343
cookie4343
  • 2,257 posts
Posted 16 January 2016 - 11:42 AM
I've tried to get them in the best position as far back as possible but the subframe tower get in the way of the gearbox going any further back, also the gear linkages prevent this also.
#12 nezbit
nezbit
  • 28 posts
Posted 16 January 2016 - 11:44 AM
get a satch shift and mod it to go in the mini!!! thats would be epic! :D I had one in my 16v s1 rallye and it was the best mod i had done
#13 acrowot
acrowot
  • 278 posts
Posted 16 January 2016 - 12:42 PM
ive put a Vauxhall box on mine because there stronger mine is only 2 speed with a bar to push it forward and back  and its in the rear ive done lots of different ones doing a 100e at the min with a ford mustang engine
#14 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 16 January 2016 - 07:23 PM
Nothing wrong with a micra engine. Good power good economy and cheap to fix. Also an easy fit under a mini
#15 acrowot
acrowot
  • 278 posts
Posted 16 January 2016 - 09:00 PM
sorry forgot to say its a ally block 3 bhp less than the cast block but a lot lighter so evens it out
