No Battery Warning Light.... Loss Of Power And Won't Turn Over
20 replies to this topic
#1 my_first_mini
my_first_mini
  • 841 posts
Posted 12 January 2016 - 03:03 PM
Hi, recently got back in the mini scene and brought myself a 1987 mini city. Collected and drove back for 3 hours, no problems :)
Few days later, driving home in the dark, lights on and after about 15 mins, I lost power and cut out, she wouldn't start or turn over, all I had was a clicking sound when attempting to start. I bump started and managed to get her home. All last week I drove to work, starting the car in the cold and wet without any problems.
Last night on my way home, cut out and lost power again, managed to bump start and lost power straight away.
I have never had a red battery light on my dash, which seems odd as all the other lighting works...
Any help would be great.
Andy
#2 gazza82
gazza82
  • 3,005 posts
  • Local Club: TMF+
Posted 12 January 2016 - 03:08 PM
You should have a red ignition light with ignition on but not running ..
Edited by gazza82, 12 January 2016 - 03:08 PM.
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 12 January 2016 - 03:39 PM
no battery lamp equals no charging, couple be wiring bulb or alternator
#4 my_first_mini
my_first_mini
  • 841 posts
Posted 12 January 2016 - 03:45 PM
I have never had the red light on, I have owned the car for three weeks now
#5 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 12 January 2016 - 04:06 PM
yes but does the light come on when you turn the key to ignition but without starting the car. if not then the light may not be working and therefore you can look at the alternator
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 12 January 2016 - 04:52 PM
As others suggested to you above, the red warning light is more than just an indicator.  It is an important part of the charging circuit that must work for the alternator to work consistently.  Suffice it to say that current flowing through the warning lamp helps energize the alternator so it starts making electricity when the engine is started.  Without the bulb alternators typically don't work.
There are the occasional alternators that will start charging the battery (without the warning light) if the engine is revved high enough.  However, those are the exceptions, not the rule.  It is also worth noting that if you are driving without using items that draw a lot of current (headlights, etc.) then you can go for days running on the battery alone without the alternator working.
I suggest you replace the warning lamp on the dash, charge the battery, and post back with your findings.  If the warning lamp does not work after replacement, have the alternator bench tested at a shop.  They typically will do this for free in anticipation you will buy a new part from their store.  If the replacing the bulb gives you a functional warning lamp, you may not have any problems going forward.
#7 my_first_mini
my_first_mini
  • 841 posts
Posted 12 January 2016 - 05:07 PM
Thanks for the feedback, will pull the dials out and check/replace the bulb. Will return with the outcome :)
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 January 2016 - 07:29 PM
Before you pull the dash out, remove the alternator plug and the small wire is the warning light wire to the red ignition light, switch the ignition on and place a jump wire into the small wire on the plug and earth it out to the engine block
If the light comes on the diode pack in the alternator has blown
If the light does not come on the bulb is blown or there is no 12v ignition feed to the bulb, or there is a break in the wiring
DON'T TOUCH THE LARGE BROWNS AS THAT WOULD BE A DEAD SHORT
Depending on the type of alternator you may not have 2 large browns and the warning light wire in a plug, they may be on separate terminals
Edited by KernowCooper, 12 January 2016 - 07:40 PM.
#9 gazza82
gazza82
  • 3,005 posts
  • Local Club: TMF+
Posted 12 January 2016 - 11:18 PM
Don't use an LED either .. Use a normal bulb if that does prove to be faulty ... Or missing!
#10 Spider
  • 14,792 posts
Posted 13 January 2016 - 07:59 AM
I run LEDs on a couple of the cars, but to get around this problem, I have them shunted with a resistor.
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 13 January 2016 - 12:54 PM
I have done that also.  However, let's not complicate the situation the OP is dealing with.
Stay with the incandescent bulb for now.
#12 my_first_mini
my_first_mini
  • 841 posts
Posted 24 January 2016 - 11:26 AM
Am I looking at the lower left hand side of the alternator?
#13 tiger99
tiger99
  • 8,584 posts
Posted 24 January 2016 - 08:11 PM
Don't know where it will be on your alternator, as they vary, but there is always one thin wire and one or two much thicker brown wires, It is the thin one that you need to jumper to earth to check that the warning light works.
On the classic Lucas alternator, there is a 3 pin plug, with springy wire locking clip, on the "back" of the alternator ("front" is pulley end). The thin wire in that plug is the one. So it is indeed on the left as you look at it.
Edited by tiger99, 24 January 2016 - 08:12 PM.
#14 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 January 2016 - 08:54 PM
The small wire in accordance with BS-AU7 wiring colours will be Brown/yellow, shorting this to earth when removed will test the ignition warning light circuit out.
#15 my_first_mini
my_first_mini
  • 841 posts
Posted 28 January 2016 - 04:11 PM
👍 I have the battery on charge now waiting to test :)
