Best Mini Fuel Cap
7 replies to this topic
#1 Agus1601
Agus1601
  • 148 posts
  • Local Club: La Tribu Mini
Posted 11 January 2016 - 03:56 PM
Hi guys! I have been changing lots of times the petrol cap and none of them sort perfectly well. Does anyone have some tips to make it no lose fuel?
Agustin
(From the other side of the world: Argentina)
#2 Avenger1992
Avenger1992
    Just On Tickover
  • 6 posts
Posted 11 January 2016 - 04:21 PM
Are you sure the issue is with the fuel cap its self and not a corroded sealing face on the tank?
If the surface is heavily pitted then it is possible that no fuel cap will seal it properly.
#3 Agus1601
Agus1601
  • 148 posts
Posted 16 January 2016 - 10:47 PM
It does seem to seal perfectly but if I complete the tank it loses some when I turn fast in a corner
#4 pickuptruck1994
pickuptruck1994
  • 366 posts
  • Local Club: Weston Mini Muckers
Posted 17 January 2016 - 12:12 AM
Are you sure its coming from the fuel cap and not over flowing via the breather ?
#5 Spider
  • 14,846 posts
Posted 17 January 2016 - 08:25 AM
I tried all the ones that I could find and for me, they all leaked when cornering, the worst for this were the locking caps, but even the non-locked leaked lots. I gave up on them all and fitted a 2" BSPP Threaded 'nipple' to the tank and modified some brass screw on caps to go on them. I did have to re-work the rubber gasket, mainly how they were held in the cap, but they don't leak a drop now.
#6 Agus1601
Agus1601
  • 148 posts
Posted 19 January 2016 - 04:42 PM
Can you help me sorting this out? I mean some easy explanation, my language is not english so some things get difficult for me
Thanks a lot
Agustin
#7 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 19 January 2016 - 05:10 PM
www.newton-equipment.de
May you will find the right cap here.
#8 Spider
  • 14,846 posts
Posted 19 January 2016 - 05:18 PM
Thanks a lot
Agustin
Hey Agustin,
All the standard caps fit with just 1/4 of a turn, though that's not necessarily the problem with them, but they just don't seem to come down tight enough on the neck of the tank.
What I was saying, is that I have cut them off and fitted a threaded pipe fitting on to the tank and have a screw on cap that has a rubber seal in it.
While they don't look quite as nice as the normal cap and not quite as quick to use, they don't leak at all.
