Hazard Warning Switch
6 replies to this topic
#1 James_eaton_thewholething
  • 1,063 posts
Posted 09 January 2016 - 10:01 AM
probably a stupid question but then again no such thing as a stupid question just stupid answers haha.
the original hazard light switch has a light in it that will flash when it is activated. the switch I want to fit doesn't illuminate when activated. now my question is do I need to fit a small warning light that will flash when the switch is activated or will the indicators flashing be enough for it to pass its MOT when the car is finished ?
regards James
Edited by James_eaton_thewholething, 09 January 2016 - 10:01 AM.
#2 johnR
johnR
  • 2,297 posts
Posted 09 January 2016 - 10:10 AM
You'll need a warning light - indicators left on can cause accidents!
#3 James_eaton_thewholething
  • 1,063 posts
Posted 09 January 2016 - 10:25 AM
I thought this was the case so I need to have a little warning light next to the switch or somewhere on the dash showing the switch is on
#4 Swift_General
Swift_General
  • 871 posts
Posted 09 January 2016 - 10:33 AM
No separate tell tale needed for hazards if your indicator tell tale flashes when you turn your hazards on. However if your indicator tell tale doesn't then yes as above you will need a separate hazard tell tale.
Edited by Swift_General, 09 January 2016 - 10:33 AM.
#5 James_eaton_thewholething
  • 1,063 posts
Posted 09 January 2016 - 10:50 AM
so if the indicator lights flash when hazard light switch is turned on then you don't need another light. the car is from 1991 so if I remember correctly the indicator lights flashed when the switch was turned on as well as the light in the rocker switch
#6 Swift_General
Swift_General
  • 871 posts
Posted 09 January 2016 - 10:56 AM
Yep. As long as your normal indicator tell tales flash when you turn the hazards on you don't need a dedicated hazard one.
#7 James_eaton_thewholething
  • 1,063 posts
Posted 09 January 2016 - 11:06 AM
 cheers mate
