REVIEW: V-5 DIY Reverse Brake and Clutch Bleeder
(Words and Photos: Classics Monthly Magazine, July 2015 issue)
Everybody has their own favourite way of bleeding brakes and it’s hard to beat the two-man operation: it may involve a lot of shouting but applying pressure to the system via the pedal is just about the only failsafe way of doing it. The major drawback though is that you do need two people which is why there are several one-man devices on the market. These include the ‘Eezi-Bleed’ type which uses air pressure to pressurise the system via the master cylinder cap, plus the vacuum bleeders which suck the fluid and air out from the bleed nipple using a one-way valve and hand plunger.
The Reverse Bleeder is similar to the hand trigger pumps but works in exactly the opposite way, by pushing fluid up the pipe into the master cylinder rather than the other way round. The idea is that fresh fluid is pushed up the pipework, with the trapped air eventually appearing in the master cylinder where it can escape.
It’s a complex-looking kit as delivered, with several adapters and lengths of pipe, plus the trigger itself.
Verdict: Simple and convenient
It’s a simple tool which is worth having around to enable quick and easy brake bleeding without having to call on an assistant. The ability to both reverse bleed and vacuum bleed makes it useful in all kinds of situations. Now to discover whether we can use it on mountain bike brakes…
Link to order here: http://www.frost.co....ems-2104-b.html
Edited by Frost Auto, 05 January 2016 - 11:54 AM.
