Top Steering Column Bush
8 replies to this topic
#1 bikenutmart
bikenutmart
  • 579 posts
Posted 04 January 2016 - 08:02 PM
Need to change the top steering column bush on my 72 850, just wondered if it is a fairly simple job, assume the column has to come out? Cheers Mart.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,991 posts
  • Name: Neil
Posted 04 January 2016 - 08:19 PM
Yes the Column needs to come off and be split down. Replace the lower one as well. On yours it will be felt so soak it in oil before fitting.
#3 bikenutmart
bikenutmart
  • 579 posts
Posted 04 January 2016 - 08:39 PM
Cheers sonikk4. Mart.
#4 sonikk4
sonikk4
  • 15,991 posts
  • Name: Neil
Posted 04 January 2016 - 08:55 PM
Mine
The state of my top and bottom bushings
#5 bikenutmart
bikenutmart
  • 579 posts
Posted 04 January 2016 - 09:18 PM
Suspect mine is bad too, as column creaks and is a bit stiff to turn, is it worth replacing the clamp bolt at the bottom? Great pics!!!
#6 sonikk4
sonikk4
  • 15,991 posts
  • Name: Neil
Posted 04 January 2016 - 09:57 PM
Check the bolt for any thread damage and it will pay you to replace the stiff nut if it does not self tighten on the bolt. The one picture i did not take was of me removing the core of the column unfortunately.
#7 bikenutmart
bikenutmart
  • 579 posts
Posted 05 January 2016 - 09:19 AM
Hi Sonikk4, Not wanting to sound thick, but is it easy to separate the inner/outer columns? Cheers Mart.
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 05 January 2016 - 09:21 AM
Yes, the inner pulls out the bottom of the outer.
Check the splines on the inner column and rack for any damage
#9 bikenutmart
bikenutmart
  • 579 posts
Posted 05 January 2016 - 01:13 PM
Cheers Carlos. Mart.
