Mk1 Scuttle Panel...
Posted 03 January 2016 - 08:33 PM
I was hoping not to replace the full scuttle panel on my mk1, and to just get away with doing the ends. However the repair panels for the ends are pretty poor and need so much fettling that I think I might buy a full scuttle panel.
Does anyone make scuttle panels for the mk1? The heritage one on Minispares seems to have two sets of holes for the wipers, whereas my car only has one set of holes. Are the panels otherwise the same? Can I just buy the panel, blank off the extra holes and use it?
Cheers,
Chris
Posted 03 January 2016 - 08:35 PM
Just blank the holes.
Posted 03 January 2016 - 08:51 PM
Posted 03 January 2016 - 09:44 PM
Also, if you do opt for the heritage Panel, you will also need to tweek the washer jet holes too as the later panel uses "d" shaped holes
Posted 04 January 2016 - 05:10 PM
I probably will go for the heritage panel, as I'm in Birmingham so I can pick one up from Minispares. I like buying panels in person as I've rejected a few in the past... Easier to do the job if you start with panels that are the right shape!
Do the D-shaped holes make a difference? Do you see them at all once the jets are fitted?
Posted 04 January 2016 - 05:16 PM
Posted 04 January 2016 - 05:47 PM
If you don't reshape the washer jet holes the standard nozzle doesn't fit. It isn't anything major - more annoying than anything if you have to adjust it after paint.
Or you could just use the later washer jets
Posted 04 January 2016 - 05:52 PM
I need to get better at my grinding though as that scuttle patch is superb, welding I have no issues just can't grind flush as good as that.
Edited by Daz1968, 04 January 2016 - 05:53 PM.
Posted 13 February 2017 - 09:04 AM
Bringing this one back from the dead....!
I've finally got round to fitting this scuttle... I've blanked off the extra holes as per Tupers post.
The washer jet holes are in a different place on the original panel compared to the new scuttle... does that sound right? I dont want to fill and redrill the holes if the original panel was somehow wrong!
Cheers,
Chris
Posted 13 February 2017 - 10:07 AM
Yes that is correct as I had to weld up mine and redrill in a different place,
Posted 15 February 2017 - 07:25 AM
Sound, cheers!
more work to do....!
