Hammer Type For Metalwork
17 replies to this topic
#16 1984mini25
1984mini25
  • 8,784 posts
Posted 02 January 2016 - 03:42 PM
The only specialist tool I use when making patches is an edge joggler.
Hardwood offcuts, angle iron, old brake discs, sockets all serve as formers, with my vice or G clamps applying the force. I tend to reach for any hammer if I want one, there's usually a bit of scrap timber directing the blow anyway. Pliers are great for forming flanges accurately by just easing the bend gradually along the fold line. If the flange is on a curved edge, bend intermittently, to leave shallow peaks that can be shrunk by hammering  the pointy "summit" against one of those improvised formers.
I do have a plumber's bossing mallet that's handy for stretching and a club hammer makes a great anvil/stake/ dolly as you can stand on the handle to keep it steady.
Remember steel work hardens, so get the maximum effect from your efforts. Constantly smacking it between two hard surfaces where it has nowhere to go hardens it more than it shapes it.
Exactly that, it's not how much the tool cost but the tool using it. I've made do with a selection of basic hammers and the odd of cut of wood over the years.
I repaired the below using nothing more than a claw hammer, some wood, a section of basic pein hammers (all with burn wooden  handles from welding) and the side of  a club hammer used as a dolly.
Edited by 1984mini25, 02 January 2016 - 03:42 PM.
#17 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 02 January 2016 - 05:17 PM
I have a set of the Clarke ones but have never really got on with them. I use three different size ball pein hammers and a short length of railway track that I fix in a vice. Like most jobs, it comes down to what works best for you.
#18 Daz1968
Daz1968
  • 2,058 posts
Posted 02 January 2016 - 05:36 PM
The screwfix one looks the same as the clarke set with the fibre glass shafts, so should be good enough as a basic set, as above though any odd bits of material and hammers can be put to good use, and I am no expert at panel beating but wanted a set with some dollies to try to learn a bit more about it. Trouble is with hammer used for other tasks is they are usually marked and this only transfers to the work. But unless you get really good at panel beating a skim of filler will be needed anyway,
