Wiring In A Push Start Button .
30 replies to this topic
#16 timmy850
timmy850
  • 3,329 posts
  • Local Club: MITG
Posted 02 January 2016 - 12:49 PM
My Mk1 has the factory starter button on the floor, so you need the key in the switch panel turned onto ON then hit the start.
There is a video on installing one here:
#17 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 02 January 2016 - 12:52 PM
http://www.ebay.co.u...tm/262182699125
Iv always thought this would be fun, would have to loose steering lock though
I thought about RFID entry a while back but its far too easy to crack unless you have a complex changing encryption. Not so much of an issue yet as its still not a very commonly used technology and you wouldn't expect it to be used in a classic, but as it is getting more popular it will also get more likely to be broken into.
Let's be honest though, how easy is it to Hotwire a mini? Very! So it's only the last of steering lock that makes it less secure, so couple it with a good alarm and I don't see an issue really
#18 Alex_B
Alex_B
  • 4,573 posts
Posted 02 January 2016 - 12:57 PM
That is a very good point, and anyone capable of hacking an rfid system could also probably get an engine started.
#19 CityEPete
CityEPete
  • 3,920 posts
Posted 02 January 2016 - 01:59 PM
To be honest I think the steering lock is less of an issue than the ignition being left on when it is done using 3 standard flip switches, the proper ones have a red flip up cover which is then used to stop the car by knocking it down which is just as cool as pressing the starter button to start it IMO?!
#20 Cooperman
  • 23,278 posts
Posted 02 January 2016 - 03:33 PM
A switch for the main ignition feed circuit is not a good idea. Not because of the theft issue as it is very easy to steal any car, but because it is too easy to leave the ignition on after parking.
With the Mk1 & Mk2 with the key in the centre it is hard to reach the key when strapped in with full harness belts, plus a button start switch is more reliable that the key type. I am pleased with mine as the button is on the right side of my self-made driver's instrument panel near the auxiliary light switches and within reach of my right hand. In a case of a stalled engine on a test I can be selecting 1st gear with my left hand whilst hitting the easy-to-reach starter button with my right hand and all without having to try to lean forward and with the belts still very tight.
I don't think it really worthwhile fitting a push button start switch in a normal road Mini.
#21 CityEPete
CityEPete
  • 3,920 posts
Posted 02 January 2016 - 05:48 PM
That is what the kill switch does that im referring to, by pressing the red cap to kill the engine you automatically switch the ignition back off, you then have to lift it up next time to start the car so only stalling the car would cause a problem if you happened to stall where you wanted to stop. Of course a regular ignition barrel solves all of these problems and gives a steering lock hence why almost every car has one, Bini ironically not one of them and does have a push start.
#22 johnR
johnR
  • 2,297 posts
Posted 02 January 2016 - 06:26 PM
When I changed my switches to mark 1 style I just moved the starter feed from the third position on the ignition switch to the new starter button (on the left of the aux. switch panel)022_zpsplpxmnqj.jpg
#23 CityEPete
CityEPete
  • 3,920 posts
Posted 02 January 2016 - 06:36 PM
^I think thats the best bet for a road car just to have the fun of the button. Does the key kill the starter button or can it still turn the engine like an old fashioned button starter, I've had people pull my morris minor one with the car in gear!
#24 Cooperman
  • 23,278 posts
Posted 02 January 2016 - 07:23 PM
When you keep the key for ignition it will, of course, still turn into the 'start' position but nothing will happen. You could put the button in between the front seats on a small discrete bracket. Now that would confuse any potential thief.
With the Mk.1 & Mk2 cars it was possible to start one and drive off in around 15 seconds. All you needed was a short length of 1" diameter pipe and a 3d bit (that's a 3 old-pence coin). You used the pipe to slide over the door handle and pushing down snapped the small pawl in the handle mechanism. Then the 3d bit was put across the under bonnet fuse box where it just pushed in. That put the ign. on and you just jumped in and pushed the starter button which was between the seats. There was no bonnet lock. So if you lost your key it really was no problem :ohno: .
#25 CityEPete
CityEPete
  • 3,920 posts
Posted 02 January 2016 - 07:26 PM
Turning over when in gear when 'mates' or 'curious children' press the button isnt great imo.
#26 Cooperman
  • 23,278 posts
Posted 02 January 2016 - 07:31 PM
The signal power to the button comes from the ignition 'on' circuit, so the button only engaged the starter motor when the ignition is 'on'.
#27 CityEPete
CityEPete
  • 3,920 posts
Posted 02 January 2016 - 08:52 PM
Thats good then, my morris minor one is just a mechanical link between the battery and the starter motor wire!
#28 slowy
slowy
  • 71 posts
Posted 02 January 2016 - 09:22 PM
Thanks for all the idea's l think Cooperman has the best solution l will try this way for now.
#29 Cooperman
  • 23,278 posts
Posted 02 January 2016 - 11:19 PM
Here is the dashboards of my 'S'. The push button starter is just to the right of the upper instrument, the voltmeter, on the driver's panel. I can easily reach it when strapped tightly in and it's quick to re-start if I stall it. It could have gone between the seats, but I need both hands if I stall it and the left hand would be selecting 1st gear. Anyway, the electrics master cut-off switch is between the seats as it must be easily reached by either crew member and that is an ideal place.
Edited by Cooperman, 02 January 2016 - 11:26 PM.
#30 86mayfair
86mayfair
  • 557 posts
Posted 03 January 2016 - 01:47 AM
Some of the single seaters I work on you can use the starter button without the ignition on. Good for making sure you have oil pressure if it's been a while since it was last started
