Tetrosyl Tetra Schutz - Thoughts?
13 replies to this topic
#1 Mon_Papillon
Mon_Papillon
  • 145 posts
  • Local Club: Norfolk??
Posted 21 December 2015 - 02:57 PM
Hello All,
I am currently in the process of stripping and treating the underside (scraping back old waxoyl and underseal etc).
I am pleased to say that the underside is in good condition, a mixture of original paint, metal and some surface rust – I plan to wire brush and remove any loose materials and I plan to use the POR15 process on the sub frames and treat any surface rust with an inhibitor.
I would then like to cover or protect the whole lot with something similar to the original rubberized underseal I have come across Tetrosyl Tetra Schutz (http://classiccarpai...l-tetra-schutz/) and seems to fit the bill – can you confirm if it would be OK for my plans?
Would it adhere well to the mixture of surfaces – I will give the surfaces a 'key' prior to application.
Oh an unfortunately I do not have access to a compressor so an aerosol seems convenient.
Thanks in advance
I will of course be waxoyling inside any box sections etc.
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 21 December 2015 - 03:29 PM
I am sure there will be a wealth of different opinions and I can only be of limited help. I have recently redone one of ours with tetra Schultz and am pleased with how it went on, did use a small compressor, how it dried and the overall finish. I then used wax oil over the finish as added protection. So although I have used it and am pleased with it it has not been on long enough and subjected to a lot of use so I cannot say yet how it will hold up.
#3 Mon_Papillon
Mon_Papillon
  • 145 posts
Posted 21 December 2015 - 03:34 PM
Thanks RedRuby, my car isn't a daily and only gets used on dry days so absolute protection isn't a major factor - I just want a dry surface that will protect and look nice'ish.  Did you go clear or black waxoyl over the top?
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,034 posts
  • Name: Neil
Posted 21 December 2015 - 04:01 PM
I have used that particular brand and had good results. My choice though is Gravitex. This went on far better i thought than Tetrosyl.
#5 Mon_Papillon
Mon_Papillon
  • 145 posts
Posted 21 December 2015 - 04:15 PM
Who makes Gravitex and can you get it as an aerosol?
#6 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 21 December 2015 - 04:16 PM
Upol is the maker of gravitex will be using this myself soon
#7 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 21 December 2015 - 04:18 PM
Not 100% sure about that. I normally use it in 1ltr containers and a schutz gun.
#8 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 21 December 2015 - 04:19 PM
http://www.ebay.co.u...ps=true&ff13=80
#9 sonikk4
sonikk4
  • 16,034 posts
  • Name: Neil
Posted 21 December 2015 - 04:20 PM
http://www.ebay.co.u...sd=290923600477
#10 Mon_Papillon
Mon_Papillon
  • 145 posts
Posted 21 December 2015 - 04:23 PM
Superb Sonikk - I assume that the Gravi-Guard is the same as Gravitex just in Aersol form.
#11 Mon_Papillon
Mon_Papillon
  • 145 posts
Posted 21 December 2015 - 04:35 PM
I have just spoken with U-Pol technical department who confirm that Gravitex and Gravi-Gard are indeed the same product.
I have decided to give that a go.  Thanks
#12 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 21 December 2015 - 04:36 PM
I use Tetra Schultz everytime and have had very good results from long term use... goes on easy and sticks to anything - wet or dry or covered in oil and grease... the only thing is its a bit 'spitty' when exiting the aerosol and gets everywhere... but if you use it - make sure to mask off everything that you dont want covering in the stuff, as its a B~~~~~d to remove afterwards...
#13 Mon_Papillon
Mon_Papillon
  • 145 posts
Posted 21 December 2015 - 04:38 PM
Thanks Minifreek - I will indeed mask up and also cover myself well!
The whole cleaning and sorting the underside isn't a clean job but I have to say its nice getting to know my new mini intimately :)
#14 The Principal
The Principal
  • 763 posts
Posted 21 December 2015 - 05:05 PM
I have used Tetra Schultz spayed it in all the usual hard to reach areas with a compressor and gun, six years later looking good although its not a daily driver
