Vtec Mini Fuel Surge On Track With Full Tank?!
4 replies to this topic
#1 Luigi33
Luigi33
  • 79 posts
Posted 20 December 2015 - 02:49 PM
I have taken my Zcar mini vtec to brands on Friday and was suffering from hesitation coming out of corners (mostly the 2 left hand bends). It is not possible to replicate any issues in a straight line or on rolling road. I filled the tank to the brim and still suffered the same problem. Is it possible for fuel to starve even on full tank and has anyone ever experienced this. My fuel tank looks to be standard set up:
#2 KTM kid
KTM kid
  • 227 posts
  • Local Club: Crews missels
Posted 30 January 2016 - 12:17 AM
Yes looks like mine, your not getting air into lines in corners are you, is your pump, regulator ok. what fuel lines are you running?
#3 Luigi33
Luigi33
  • 79 posts
Posted 04 February 2016 - 09:09 PM
Ktm the car is off the road at the moment and in storage having some work done. Will take another look at it when its back
Somethings to note - fuel pressure stays at steady 2.7 bar and regulator is on the return line at the front right by the tank
#4 nicklouse
  • 18,578 posts
Posted 04 February 2016 - 09:30 PM
If your pressure is staying constant then I would be changing yout thoughts on the cause of the problem.
I would look at an electrical problem.
#5 KTM kid
KTM kid
  • 227 posts
Posted 08 February 2016 - 02:37 PM
I can see you regulator in picture, I have mine in back next to fuel rail. agree with Nicklouse, if your pressure is not dropping, then 9 times out of 10 it will not be fuel,
