something that has always had me wondering.
but what is the actual difference between, say, a stone cutting disc and a steel cutting disc?
they look just the same but?
I am guessing not that much.
Posted 16 December 2015 - 03:18 PM
Posted 16 December 2015 - 03:20 PM
Stone discs will cut steel.. But steel wont cut stone
Posted 16 December 2015 - 03:43 PM
Is that like rock, paper, scissors but for grinders?!
I would assume there will be different substances in the abrasives, even though the structure is largely the same. Discs for stainless usually look a bit different.
Posted 16 December 2015 - 03:53 PM
Posted 16 December 2015 - 03:55 PM
If cutting metal don't use the 3mm thick disc use the 1mm much better
but 1mm fail more often I have found. but that was not the question.
Posted 16 December 2015 - 04:01 PM
Posted 16 December 2015 - 04:02 PM
Posted 16 December 2015 - 04:04 PM
You are possibly loading the disc ? I haven't had a decent brand ever fail, but I don't lean on the grinder or try and make it flex (not that I'm implying you do)but 1mm fail more often I have found. but that was not the question.If cutting metal don't use the 3mm thick disc use the 1mm much better
Posted 16 December 2015 - 04:07 PM
FS
I've never had a 1mm cutting disc fail either
Posted 16 December 2015 - 04:28 PM
Metal cutting disks do cut concrete paving slabs, eventually... luckily it was just the one paving slab that needed cutting, plus you only need to cut half way before breaking with a hammer/rubber mallet.
Posted 16 December 2015 - 04:52 PM
make sure they are in date!!!!! and the difference is the material and structure and quality 1mm discs are fine, might get the ode one fail due to a snag but to be honest i use 100's of discs and would not use any thicker than 1mm for cutting
dave
Posted 16 December 2015 - 05:11 PM
In my experience the metal cutting/grinding ones always seem to slice through flesh more easily than the masonry ones do!
(Note to self: must stop testing cutting discs with fingers!)
I've had the same experience with a 3mm stone cutting disc ...top of my thumb almost chopped off ...so your are not alone
Posted 16 December 2015 - 06:35 PM
Posted 16 December 2015 - 06:57 PM
I usually buy a good branded disc for example Sait or 3m but recently tried a couple of the Chinese ones from my supplier and they lasted very well considering that they are 50% cheaper, I usually buy them by the 100 so I've got a good amount in stock ready for when I finally start my Mk 1 !
Posted 17 December 2015 - 12:41 PM
beware of any cheap 1mm cutting discs with a 'lip' around the inner edge (i.e. they aren't flat).
they are the only ones I have ever broken (repeatedly).
