Engine Numbers
19 replies to this topic
#1 John.Wilkinson
John.Wilkinson
    Just On Tickover
  • 7 posts
  • Local Club: Cape Town classic mini
Posted 15 December 2015 - 09:05 PM
Hi all
I found a number stamped (looked like individual numbers/letters on a series of punches had been used) into the engine block of my car, viz: 8AMUH82041
Does anyone recognise such a number?
It was on the side of the block immediately under the extension to the head that holds the thermostat housing.
#2 Spider
  • 14,854 posts
Posted 15 December 2015 - 09:15 PM
It sounds very much like an 850 Engine that was fitted to an Aust bulit 850 Saloon or Van, with the 'pudding stirrer' type gearshifter.
8AMUH82041
8AM     850 saloon / van engine
U          Central type Gear Shift
H          coff coff High Compression (a whooping 8.3:1!!)
82041  individual no.
Edited by Moke Spider, 15 December 2015 - 09:22 PM.
#3 crazicarl
crazicarl
  • Just Joined
  • 64 posts
Posted 15 December 2015 - 10:51 PM
It seems that some features on South African minis and Australian minis were quite similar, my engine number is not too dissimilar, except that its a 998, not an 850.
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 15 December 2015 - 10:54 PM
High compression.... I'd like to see a low compression equivalent!
#5 crazicarl
crazicarl
  • Just Joined
  • 64 posts
Posted 15 December 2015 - 10:57 PM
What would 9AKUH... be?
I know the 9 = 998
U = as you say magic wand gear lever, but I think mine has been changed at some point to remote box.
H = high compression
AK = ????
#6 Spider
  • 14,854 posts
Posted 16 December 2015 - 02:10 AM
That one appears to be a UK engine, I wouldn't take this a gospel, but the best I have;-
9AKUH
9 = 998  (this would be pre approx 71 to 73 when they went to the 99)
A = Auto
K = Positive Crankcase Ventilation to the Inlet Manifold (PCV System in normal speak - this also lines up the '9' instead of the '99')
U = Central Shift (OK, maybe they called it that?)
It also doesn't 'look' right to me, but then again,,,,,,
Hold on to yr jocks,,,,,,,,,  7.8:1 - it's a wonder they could run!
Edited by Moke Spider, 16 December 2015 - 02:11 AM.
#7 Spider
  • 14,854 posts
Posted 16 December 2015 - 02:15 AM
I know for a while we did export some parts to SA, doors for one item.
The 850 engines, while being stamped here with a local number, were in fact fully imported here as a complete more or less ready to fit power unit, they cut off the engine tag and then stamped the blocks to comply with local laws. When they developed our Mini Deluxe, they started doing our own engines here.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 December 2015 - 09:52 AM
9AKUH
A = Auto
The "A" is a hangover from when Austin and Morris were separate... so 8A* and 9A* were Austin engines and 8M and 9M were Morris, then 8AM, 9AM when they joined... and later the M was changed depending upon the specification of the engine... which is where the 9AK comes from...
A is not AUTO, but a 9AH or 8AH engine is an auto... (the H is the key letter)
However, this is for UK built units, what they were stamped as in ZA and AU can be different.
In 1969/70 the more familiar 8H, 99H, 10H and 12H prefixes were introduced.
#9 Spider
  • 14,854 posts
Posted 16 December 2015 - 07:40 PM
9AKUH
A = Auto
Yes, in the UK number system, MA was Austin / Morris, but Minis were ONLY ever sold here under the Morris Badge and the system is slightly different
Thanks for the clarification on the 'AK', all auto engines / gearboxes were fully imported complete units out here, I was working from that list above, and this UK listing here (sorry for the quality of it)
but, as I said in my earlier post, it didn't look right. Cheers.
Edited by Moke Spider, 16 December 2015 - 07:42 PM.
#10 crazicarl
crazicarl
  • Just Joined
  • 64 posts
Posted 16 December 2015 - 10:45 PM
Just came across this from a South African mini website.
"9AK
South African manufactured block"
So that answers that question.
#11 Spider
  • 14,854 posts
Posted 17 December 2015 - 03:00 AM
"9AK
Well, there you go.
I don't have any South African Info, but there's a BIG story to be told there. Come to think of it, I think there was a book published a few years back.
#12 crazicarl
crazicarl
  • Just Joined
  • 64 posts
Posted 17 December 2015 - 02:39 PM
Yup, I bought a copy. It doesn't have too much info on the pick-up, but has some other useful info. I think it was called the South African mini story by Ryno Verster.
#13 iMini1000
iMini1000
    Starting My Mini Up
  • 1 posts
Posted 28 December 2015 - 04:35 PM
So what conclusion can be drawn from an engine with s/n : 99H353E-Hxxxxx (5x is I presume the individual number) ?
Could be deduced the year of make?
#14 Spider
  • 14,854 posts
Posted 28 December 2015 - 06:15 PM
998, with a negative earth Dynamo and a Rod Shift Gearbox so I guess from those ancillaries, the year could be narrowed down.
#15 peterh2
peterh2
  • 44 posts
Posted 30 December 2015 - 05:19 PM
To high jack the thread slightly
The engine number tag on mine is so corroded I can't read anything. The V5 lists the engine number as -359554.
The car is 998cc . First reg. 02/03/1979 in UK.
How can I find the correct number?      Heritage Centre - Gaydon ?
