Are All Classic Mini Doors, The Same?
21 replies to this topic
#1 Poppet2
Poppet2
  • 135 posts
Posted 15 December 2015 - 06:37 PM
I need a new driver's door. My mini is a 1984 one, not sure what mark though.
Will it make any difference whether the replacement door is a Mk 1,2,3 or 4?
Are the doors all the same?
Also, what exacatly is a re-skin service?
Edited by Poppet2, 15 December 2015 - 06:38 PM.
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 15 December 2015 - 06:38 PM
Early external hinged ones are different, but in all honesty, doors seem to vary from car to car.
It might be worth getting yours 're-skinned
#3 Poppet2
Poppet2
  • 135 posts
Posted 15 December 2015 - 06:40 PM
What exactly does re-skinned mean?
#4 Dusky
Dusky
  • 5,322 posts
Posted 15 December 2015 - 06:48 PM
Early models have a rounded door edge, where later have a corner. Bottom right of the door on the lh side, bottom left on the rh.
#5 jpw1275
jpw1275
  • 2,803 posts
Posted 15 December 2015 - 06:58 PM
Hi , re skinning the door requires taking the outer skin off so you are left with this
Cheers James
#6 Poppet2
Poppet2
  • 135 posts
Posted 15 December 2015 - 07:01 PM
Thanks.
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 December 2015 - 07:08 PM
Later cars had side impact bars too so there is another difference.
Although these doors would fit Mk3 onwards.
If you have your door re-skinned, this is a better option than a second hand door as although it may appear solid, you can bet your bottom dollar that there will be rust in the seams between the skin and frame.
A brand new door is also very expensive so re-skinning is more cost effective.
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Mk1 MK2 external hinged, MK3 onwards internal hinge and will fit any internal hinged car.
The later MPI doors had an internal crash bar fitted.
#9 Poppet2
Poppet2
  • 135 posts
Posted 15 December 2015 - 07:16 PM
I am buying a reconditioned, primed, re-skinned mk 3 door.
However, someone mentioned that not all mini doors are the same, so I am hoping it will fit my 1984 mini.
#10 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 15 December 2015 - 07:21 PM
A MK3 door will be an internal hinged door and will fit your car.
#11 Swift_General
Swift_General
  • 871 posts
Posted 15 December 2015 - 07:22 PM
That should in theory fit your Mk4, however may need tweaking to get a good fit and gaps right.
#12 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 December 2015 - 07:23 PM
They could have also meant that a door from another Mini even if the same type may not fit well.
Every Mini is slightly different so your original door might fit well and have nice even gaps all round, but you might find that the replacement doesn't...
In this case, shims are your friend, that and perhaps a bit of muscle to twist the door slightly to make the fit even
#13 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 15 December 2015 - 07:25 PM
A lot also depends on the skin used so either Heritage or Magnum. As Ben has mentioned unless its the car original door then there will always be a slight mismatch. Shimming and various tweaking will get you the majority of the way. Sometimes you will need to get heavy handed as well. Pieces of wood etc.
The gapping however can be very hit or miss. It really depends on what your expectations are.
#14 Poppet2
Poppet2
  • 135 posts
Posted 15 December 2015 - 07:36 PM
Thanks for your replies everyone.
#15 Spider
  • 14,838 posts
Posted 15 December 2015 - 08:49 PM
Cheers James
Put some clothes on!  Naked doors on the forum, what next?  Topless carbs?
