Fuel Line Size
19 replies to this topic
#1 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 12 December 2015 - 09:15 PM
Hi
Is it 8mm fuel line I need. I'm using a gt17 turbo and metro turbo hif44. I no I need to run 2 so I have a return
#2 Ethel
  • 25,922 posts
Posted 12 December 2015 - 10:56 PM
I reckon the Metty had 8mm lines because that's what the pressure regulator and pump had. I think 1/4" (6mm) would suffice, it'll depend on your pump's pressure and how much juice the engine needs (target BHP).
#3 bluemini1979
bluemini1979
  • 619 posts
Posted 12 December 2015 - 11:11 PM
Target is 130hp. I haven't bought a pump yet but painting the floors on Monday and putting rear frame in Tuesday so need fuel lines in before subframes
#4 coopdog
coopdog
  • 4,506 posts
Posted 13 December 2015 - 10:35 AM
8mm for both :)
#5 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 13 December 2015 - 06:46 PM
I would go for 10mm and a 8mm return. You don't want performance compromised for the sake of spenfing a couple of quid more, and it would future proof things if you want to go for higher power in the future. The standard spi fuel line is 10mm.imo
#6 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 13 December 2015 - 07:01 PM
10mm? Inner diameter? Are you sure? :-|
#7 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 December 2015 - 07:21 PM
No, outer diameter. Of course any hoses off the fixed fuel line would be 10mm inner.
Edited by HUBBA.HUBBA, 13 December 2015 - 07:22 PM.
#8 bluemini1979
bluemini1979
  • 619 posts
Posted 13 December 2015 - 08:07 PM
Why feed with a bigger pipe? Surely if 10mm of fuel can get there 10mm of fuel would need to come away. I work on hydraulics and they always have a larger return
#9 kezzkitkat
kezzkitkat
  • 714 posts
Posted 13 December 2015 - 08:11 PM
to be honest people have ran 6mm on both or 8mm on both or the common 8/10mm return
i personal run 8mm on both and have no trouble
you will need around 4 meter each way
#10 bluemini1979
bluemini1979
  • 619 posts
Posted 13 December 2015 - 09:14 PM
Ok thanks my dads a plumber and has a new roll of 8mm on his van so I'll nick a bit of that ;)
#11 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 December 2015 - 10:42 PM
Less fuel is being returned to the fuel tank than leaving the fuel tank as some of the fuel will be used to run the thing at the front of your car called an engine. :-) There will be less flow and less pressure on the return. All it's doing is returning unused fuel back to the tank via the regulator.
Out of interest aren't hydraulics returns pumped?
Edited by HUBBA.HUBBA, 14 December 2015 - 08:13 AM.
#12 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 17 December 2015 - 09:13 PM
8mm feed, 10mm return.
Get any kind of restriction in your return and you'll have fuel pressure issues.
#13 Ethel
  • 25,922 posts
Posted 17 December 2015 - 09:51 PM
That makes sense as the regulator will be held open if the pressure can't leak away fast enough. Though bigger lines hold more fuel for inertia to act on. 6mm ought to flow plenty of juice for most though. Feeding the return back in just before the pump inlet should held flow in both directions, especially if you have a carb Mini tank with a 6mm outlet.
#14 mad mk1
mad mk1
  • 746 posts
  • Local Club: TurboMinis.co.uk
Posted 19 December 2015 - 06:05 PM
I find 8mm both ways works fine with 200+ Bhp
so it's up to you
#15 burchy35
burchy35
  • 114 posts
Posted 25 December 2015 - 12:36 PM
8mm feed, 10mm return.  no problem with 180bhp i run.  ;D
