Focus Steering/scraping Issues
Posted 01 December 2015 - 03:56 PM
One suggestion was wheel bearings. I have tested the play by holding at 6 and 12 - nothing. Not conclusive though. Wheels off, brakes off, spin the wheels. No scraping noises or anything immediately wrong. I have both front wheels off to compare each side.
When I hold the wheel solid, I can't move the driveshafts by themselves. When I let go of the wheel and twist the shafts there is around 1-2 mm of movement before it 'clunks'; this again is the same both sides and pretty much what I would expect. When I say clunk ita just the ball bits picking up their holder, if that makes sense. Not sure of the technical terms.
I'm reluctant to change the bearings at the moment only to find out its not that as I don't want to have to take it all apart again afterwards and get another hub nut etc.
There were no advisories on last MOT, which while not conclusive shows the levels of play are all OK.
It doesn't tend to happen so much at slower speeds on sharp turns, I.e roundabouts but more at say 60 on a longer right turn. At faster speeds (70) I couldn't hear it earlier but the wind noise is loud so it's harder to identify. This is just from today. Previously, I could have sworn it was around 40-50mph plus.
It's on 90k, and apart from shock/spring (passenger side, replaced as soon as I got it because it was snapped), I believe all original suspension components. Its been like this for a while (I I should have got it done sooner but can't have the car off the road so not had a good opportunity). I'm off work this week so a bit of time to play with, although need it sorted for Friday.
Any thoughts would be much appreciated.
Posted 01 December 2015 - 04:05 PM
Posted 01 December 2015 - 04:46 PM
Posted 03 December 2015 - 02:24 PM
Secondly I have had the new bearings pressed in, put everything back together and the lower caliper bolt hole thread is screwed. So, I either need to retap it (never done it, but it looks straightforward (but I don't have the tool!). This also means I'll need a slightly bigger bolt to go in it, not sure I'll find one the right type? The other option is a complete number but I'll be so angry with that. I've just had the bearing pressed so they will both be ******* and I'll need to spend more money. And won't be able to use the car tomorrow.
Posted 03 December 2015 - 02:29 PM
Posted 03 December 2015 - 02:50 PM
I would use a vise-grip or some other set of large pliers to clamp the tie rod end onto the steering arm so it will go deeper into the taper while spinning the nut. On the caliper bolt, I would get the replacement OE bolt and a matching thread repair kit, something like this:
http://www.amazon.co...coil repair kit
Posted 03 December 2015 - 03:24 PM
Posted 03 December 2015 - 04:12 PM
Posted 03 December 2015 - 06:06 PM
Get a repair kit that includes the drill bit, that will "remove" the old thread. That way everything is matched and there are no worries about the hole size vs. the tap size and so on. You will like the finished product. It might be better than new.
Edited by xrocketengineer, 03 December 2015 - 06:08 PM.
Posted 03 December 2015 - 07:54 PM
So I went to Band Q and they only have the tap and die sets, with no inserts. Halfords only sell it online. Oh well, if I order tonight I'll have it Saturday to get the car fixed but that's the weekend plans cancelled!
Thanks Rocket Engineer for the help. For what it is worth, I did think I would have to retap the holes. Having never done it, I though it was going to be more difficult, but I have watched a couple of videos on YouTube and it looks easy enough and most importantly, I can do it with the hubs still in pace.
All I wanted to do was stop the scraping noise. No wonder garage labour rates are high!
Edited by Black.Ghost, 03 December 2015 - 10:48 PM.
Posted 03 December 2015 - 11:51 PM
When I replaced radius arms on the Mini, I broke one bolt on the subframe. So I ended up using a repair kit so the threads and bolts would still be the original size.
The kit I used. I already had the matching drill bit:
Drilled and tapped:
Helicoil on the tool:
Helicoil installed:
Bolt fit check:
Posted 03 December 2015 - 11:53 PM
Oops! Double entry.
Edited by xrocketengineer, 03 December 2015 - 11:54 PM.
Posted 05 December 2015 - 05:09 PM
After doing the front though, the scraping appears thus far to have been banished, and the front is nice and soft over speed bumps now! The rear bangs a bit so I think the next thing to do will be take a look at that and I might put new rear brakes on at the same time as the fronts have just been done. She is wearing her winter boots as well now.
I noticed as well you can get reasonable hydraulic presses for around £130 for 20T and around 80 or so for 12T. That might be my next investment.
Quite pleased with the results over the last couple of days, despite the time taken!
Posted 05 December 2015 - 07:20 PM
Great to know that you got it all fixed.
