Hi guys. Newbie with a silly problem.
The temp gauge goes to 100% when I ground it, but when I heat the sender valve, the gauge starts to rise and then cuts out.
First discovered the problem actually starting the motor and letting it warm up: The gauge would start to rise and then cut out. Now I'm testing it outside the motor. I have even used direct wiring to the spare gauge.
Two different gauges, two new sender valves: same result.
Could it be the voltage stabilizer? (I don't have a spare one to test with).
(After a test, grounding the gauge doesn't work until the car has been sitting a few minutes.
All this is without actually starting the car, just heating the sender valve outside the motor)
1969 Spanish Mini 1000:
Motor Code - (G) I-0982
Chassis No. - I-00355
