1999 Cooper Sportspack @ Mill Road Garage
307 replies to this topic
#241 toplessmini
toplessmini
  • 498 posts
  • Local Club: none on the island....
Posted 13 March 2017 - 07:51 PM
I'm home on Wednesday, I'll definitely need to see it in the flesh........
Looking good....
#242 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 March 2017 - 08:04 PM
Looking good....
Absolutely mate.
I look forward to seeing you.
Ben
#243 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 March 2017 - 07:16 PM
A few more bits done today.
Tomorrow is going to be an all dayer so progress should be good.
I refitted the windscreen with a new rubber and fillet strip.
I have also fitted the de-mister vents and top dash rail.
Also now fitted but not pictured is the gutter trim and i have vacuumed the carpets ready for the seats to go back in.
I aim to get the engine painted tomorrow morning so that it can go back in as that is the one thing that is going to hold up further progress until it's done.
More tomorrow
Ben
#244 jamesquintin
jamesquintin
  • 1,025 posts
Posted 15 March 2017 - 10:36 PM
Where do you get your silver fillet strip? Mine was replaced a few years ago, but the silver/chrome quickly faded away looking a bit rubbish. Need something that will look a bit better for longer...
#245 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 March 2017 - 06:36 PM
The customer supplied pretty much all of the parts himself so i'm not sure where it came from. The rubber itself came from pheonix trims so it's possible the fillet came from there too.
Sorry i can't be more help.
Ben
#246 toplessmini
toplessmini
  • 498 posts
Posted 16 March 2017 - 07:36 PM
I picked it up at a car show, may have been Beaulieu. I must say I've had it a couple of years.
#247 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 March 2017 - 07:15 PM
More progress the past 2 days.
I have re-fitted most of the interior
I still need to put in the radio, the centre console and bolt in the dash board which i have left loose for the time being until the car is running and everything is checked and working.
I de-greased the engine again, identified an oil leak and then prepped it for paint.
Here it is masked off and in primer
Once that had flashed off, i applied the yellow top coat.
I have no picture at this stage but there is one coming up.
The next task was to gather all of the engine ancillaries and brackets and prep them for paint. As usual, everything was greasy and rusty so took a fair amount of time to get prepped.
Once they were ready, I got them into the booth, then primed and painted them.
As you can see, i re painted the servo, servo bracket and the fog light brackets at the same time as i wasn't 100% happy with the finish before.
I also painted the timing chain cover at the same time
Once it had cured enough, i de-masked the engine to get a photo of the yellow :-)
Whilst the black parts were baking, i assembled the new front hubs.
They have been assembled with Timken bearings, NOS Xpart ball joints and new steering arms.
By then, the black parts were hard and i could begin bolting them back to the engine
As you can see, I have refitted the alternator brackets, waterpump, top pully, engine mounts and not pictured is the new clutch slave and breather.
Then engine is now ready to drop into the car so not too much longer now and it will be finished.
Ben
#248 toplessmini
toplessmini
  • 498 posts
Posted 17 March 2017 - 07:58 PM
I think I've figured out the mystery part.....
https://www.minispor...-injection.html
#249 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 March 2017 - 08:47 PM
Yep, I  looked it up today.
That box we looked in yesterday contained the bottom and top steady kit. I just didn't look closly enough to realise  :rolleyes:
#250 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 March 2017 - 08:04 PM
More progress today.
I need to get the engine fitted today so i can get the car rolling as it needs to be moved.
Before i put it in, i needed to sort the oil leak that i found.
Oil was weeping from the bottom of the diff side cover so it's much easier to sort with the engine out of the car.
with the pot joint off and the cover removed, It was quite a surprise that it hadn't been leaking more
There was just a small amount of gasket sealant in places and the majority of the mating surfaces were metal to metal.
It's now resealed and back together so no more oil leak. :-)
With that done, i lifted the engine into the engine bay and fastened it to the subframe
I have left the engine steadies out for the time being to aid fitting the exhaust system.
With that done, i installed the hubs, brakes and driveshafts onto the car
Then refitted the wheels and dropped it onto the ground
That's as far as i got today as i needed to empty the workshop out to better organise it and get the restoration jobs ongoing into better positions to save having to keep moving them around.
So now they are in more of a line up which makes things much easier and better utilises the space that i have whilst giving good access to the spray booth
Once i had finished tidying, i set about installing the exhaust system.
I had to dismantle it to get it in so it fought me all the way where the joints were seized together but it came apart and all the joints cleaned up nicely ready to reseal
I need to do a floor pan repair on the green MGB in the morning but aim to get the rest of the engine plumbing completed in the afternoon.
Ben
#251 toplessmini
toplessmini
  • 498 posts
Posted 20 March 2017 - 08:32 PM
Almost there.....
#252 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 20 March 2017 - 09:16 PM
Almost there.....
Great choice on the engine colour.😊
#253 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 March 2017 - 08:42 PM
Today was a bit tricky juggling stuff but i did make progress, I just didn't take any photos  >_<
The exhaust system is now fitted.
The inlet manifold/injection system is installed
All the breathers and associated pipe work are in.
Simon, if you see this the top engine steady kit is the wrong one for your car. It seems unsuitable for MPI cars and won't clear the network of breathers.
Has anyone else found this? If so, can anyone recommend a kit that will fit?
Ben
#254 toplessmini
toplessmini
  • 498 posts
Posted 21 March 2017 - 08:59 PM
Ben
That's not good, I'll have to have a rethink.......
Do you think it's for the SPI?
Edited by toplessmini, 21 March 2017 - 09:07 PM.
#255 toplessmini
toplessmini
  • 498 posts
Posted 21 March 2017 - 09:32 PM
http://www.dsnclassi...osport-rhd-mpi/
Would this be more suited for the job?
