1999 Cooper Sportspack @ Mill Road Garage
304 replies to this topic
#226 jamesquintin
jamesquintin
  • 1,017 posts
Posted 08 March 2017 - 09:03 AM
It's too late now, but did you manage to save the body number from the original front end (on the bonnet slam panel infront of the radiator)? One thing I'm missing from mine :(
#227 Steve220
Steve220
  • 5,033 posts
  • Local Club: BMC
Posted 08 March 2017 - 12:24 PM
Seems to be a popular topic on the Facebook group! Managed to get all but one number left from mine
#228 jamesquintin
jamesquintin
  • 1,017 posts
Posted 08 March 2017 - 01:03 PM
yeah, thats my topic ;)
#229 Steve220
Steve220
  • 5,033 posts
  • Local Club: BMC
Posted 08 March 2017 - 01:23 PM
I know, I've been chatting to you in it.
#230 jamesquintin
jamesquintin
  • 1,017 posts
Posted 08 March 2017 - 02:23 PM
#awkward
#231 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 March 2017 - 06:29 PM
I still have all of the panels i removed but unfortunately, this car has had a new front end on it a few years ago and none of the numbers were transferred over from the original front end.
All i have is the VIN plate :(
Ben
#232 RT2002MCS
RT2002MCS
  • 18 posts
Posted 08 March 2017 - 07:27 PM
The attention to detail is exceptional, it's like your doing your own vehicle
Thank you for sharing
#233 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 March 2017 - 08:25 PM
A bit more done today.
First up, i de-masked the car and moved it out of the booth ready for me to paint a few other parts
And then began some prep on the sportspack arches, shock top mounts and bonnet prop
Before mounting them in the booth ready for paint
And then i painted them
Whilst they were baking off, I started masking the car ready for stonechip
And then once the bits in the booth were ready to come out, I put the car back in and sheeted it up
And then applied the stonechip
Once it had gone tacky, I de-masked it straight away as the paint is still too fresh to leave sticky tape stuck to it for too long
Once it had hardened, I moved the car back to the workshop, removed the wheelie jig and put it back on stands.
I had just about enough time to start running fuel lines, Wiring looms and heater hoses
More tomorrow..
Ben
#234 jamesquintin
jamesquintin
  • 1,017 posts
Posted 08 March 2017 - 10:10 PM
Make sure the earth behind the expansion tank is reaaaaaaaly clean, cuased me no end of problems when I had a wing replaced
#235 toplessmini
toplessmini
  • 492 posts
  • Local Club: none on the island....
Posted 09 March 2017 - 07:18 AM
Looks amazing........
#236 Pistonbroke66
Pistonbroke66
  • 89 posts
Posted 09 March 2017 - 11:33 AM
Your work is a credit to you Ben
As someone of accelerating years shall we say it is very pleasing to see we still have some top quality tradesmen at the top of their game doing work like this.
every credit to you mate
#237 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 March 2017 - 09:05 PM
Thanks for the kind words Mole End :-)
I prepped the arches so that i could black out the back inside edges.
I refitted the steering rack
As well as some of the under bonnet parts.
I only want to fit the parts that are easier without the engine in. The rest of the parts will be fitted after it's in.
I also fitted the arches
Next i wanted to start building up the subframe so i put the old and new side by side ready
Only the cones and trumpets are being salvaged from the old frame, everything else will be renewed
I started building up the other side but couldn't fit the top arm as i found i only have one knuckle joint in among the parts so another has been ordered which will be here first thing tomorrow.
It's getting there
Ben
#238 Pistonbroke66
Pistonbroke66
  • 89 posts
Posted 09 March 2017 - 09:53 PM
When you move up north.........tell me!!!
#239 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 March 2017 - 08:02 PM
I got another knuckle joint this morning so i managed to get the other side assembled.
I have had other work to tend to today so have done bits on this as and when I could.
I finished building up the subframe, waxoiled the back of it and also the bulkhead and toe board and then fitted the frame to the car
I have also fitted the top shock mounts and greased the top arms.
Next time, i need to get the engine stripped of it's ancilleries so it can be painted and fitted.
Ben
#240 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 March 2017 - 06:52 PM
I have had 3 jobs on the go today including this one so as a result, progress has suffered slightly :(
I have however refitted the doors
And the headlamps and indicators are now refitted
I have also fitted the clevis pin to the clutch pedal so the carpets and soundproofing are now back in place but i failed to get a picture of that.
I also removed the ancillaries from the engine ready for prep
Ignore the oil spill, I tipped the engine up to have a look at an oil leak and this ran out of the engine as i tipped it up.
It needs another power wash and degrease and then ill get it ready for some paint.
I shall also re-paint all of the black brackets, starter motor and the like after.
Ben
