1999 Cooper Sportspack @ Mill Road Garage
304 replies to this topic
#211 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 24 February 2017 - 09:09 AM
Ben - amazing work (bet you're tired of reading that :lol: )
Quick question - the front arch stiffeners, are they made by you or bought?
#212 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 February 2017 - 08:43 PM
Hi Steve.
Thanks for the compliments.
The arch stiffeners are made by Heritage and are the same ones used at the factory when the shells were prepped for sportspack.
Ben
Edited by Ben_O, 24 February 2017 - 08:43 PM.
#213 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 March 2017 - 09:16 PM
With all of the repairs complete,it was time to get the Mini into the booth for some primer.
And then after 3 good coats, it can sit and bake off
And then back out into the workshop.
Next up, I started prep on all of the parts that need to go gloss black.
I started off with the new front subframe
And then sorted through the removed parts for all of the brackets and other parts that needed doing.
Some are new but others were quite rusty.
I stripped off the parts from the brackets and was left with a pile of bits to prep
After de-rusting and prepping, i hung everything in the booth ready for a drop of primer
And then applied some nice gloss black to finish.
Then whilst the paint was hardening, I turned my attention to the engine.
I steam cleaned it to get the years of grime and grease off of it and it came up pretty well
I just need a decision on a new colour for the engine and then ill get the ancillaries off of it and get some fresh paint applied.
That's all for today.
Ben
#214 toplessmini
toplessmini
  • 492 posts
  • Local Club: none on the island....
Posted 01 March 2017 - 10:36 PM
How about something like this?
16422853_1231422913578376_39569881509764
#215 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 March 2017 - 10:40 PM
Yep, I can do that.
Ben
#216 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 March 2017 - 07:50 PM
Back to the prep work today.
I started off with a guide coat on the primer
And then flatted the primer
The I masked up the seams ready for seam sealer
And then applied the seam sealer
Then seam sealed and brush sealed all up under the wheel arches and inside the front panel joins
And then put the car in the booth ready for its new coat of paint tomorrow
Ben
#217 toplessmini
toplessmini
  • 492 posts
Posted 06 March 2017 - 09:05 PM
I can't wait to see it all completed........ :gimme:
#218 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 March 2017 - 09:44 PM
Not too long now :-)
#219 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2017 - 07:46 PM
So today was paint day.
I started off with a coat of paint on the top dash rail and windscreen boxing panels. This will enable me to mask the car conventionally when painting the front end
Then after that had hardened off, i gave the whole front a through degrease and masked it up
At this point, i wanted to fit the seam trims before top coating the nose as they are sealed to the body top and bottom so can't very well be done after painting.
Before fitting them, I decided to brush paint the seams with a couple of coats of top coat.
Once that had hardened, i fitted and sealed in the trims and was ready to go.
All done :-)
Tomorrow, ill paint the sportspack arches and apply the black stonechip to the under arch areas and then it can be flatted, polished and reassembly can start.
Ben
#220 toplessmini
toplessmini
  • 492 posts
Posted 07 March 2017 - 08:28 PM
Now it's looking good, great work Ben :highfive:
#221 panky
panky
  • 1,790 posts
Posted 07 March 2017 - 08:31 PM
Looks lovely, but your bonnet strips are a bit wonky ;D
#222 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2017 - 08:51 PM
Cheers.
I have the Yellow for the engine. I hope you like bright... :lol:
#223 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2017 - 08:52 PM
Ill re position them tomorrow ;-)
#224 Daz1968
Daz1968
  • 2,058 posts
Posted 07 March 2017 - 09:19 PM
Very nice, do you use solid or clear over base.
#225 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2017 - 09:44 PM
Direct gloss on this one mate but COB on all my day to day modern car jobs.
The rest of this Mini is done in solid so i did the front end the same.
Ben
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
